difficulty removing the keyfob
Old Nov 4, 2009 | 01:31 PM
rh71's Avatar
'10 C300 Sport
After turning the vehicle off, the key is in position 0 (furthest back) but it's difficult to take the key out. Need to jiggle it a bit and it feels like this is not natural. Am I doing something wrong? Didn't find anything about this in the manual.
Old Nov 4, 2009 | 02:05 PM
joshg1001's Avatar
2017 E300
yes it is hard to take out. Dont jiggle it, just pull directly out.
Old Nov 4, 2009 | 02:41 PM
omgitselaine's Avatar
Lexus IS 350 F Sport
Had the same issue a few weeks ago and i simply brought the car into the dealership and they took care of it in two days. Had a loaner and now now jiggling .... might be best to bring it in also since you really dont want to wait till it gets stuck where you cant take it out.
Old Nov 4, 2009 | 02:53 PM
Black ICE's Avatar
2008 Mercedes C 300 Sport
I had that problem when I first got my benz. Let me be the first to tell you that there is nothing wrong with your car! When you turn the car off, place your thumb on the mercedes emblem on the key fob and you index finger behind the key like you are pinching it. then just pull straight out. It should work. I had to figure it out on my own since the dealer didnt tell me that. Im sure he was jerking the key out after our test drive. lol
Old Nov 4, 2009 | 02:56 PM
TB5...'s Avatar
2009 C300 4Matic
i don't know if i had the same issue...
i DID at one point find it hard to pull out the key... but i then realized that i was being too gentle... now i grab the key chain ring and yank it straight out...
everything is ire now.
Old Nov 4, 2009 | 05:36 PM
dfordham's Avatar
2014 E350, 2012 SL550
I had that problem with a W203. There is an interlock that prevents you from removing the key unless you are in PARK. I had to make sure I put the shift lever into PARK with a little force or the key wouldn't come out.
Old Nov 4, 2009 | 05:44 PM
imboom's Avatar
Had the problem when the car was new and everything was a tight fit. I was just being too gentle on taking it out. Just takes a stern force. However, if it doesn't feel right then you may want to get it checked out.
