Squeaky Pulleys
Old Nov 9, 2009 | 03:37 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
Squeaky Pulleys
Hey everyone,
since it has gotten a bit cooler, upon start-up my car makes a squeaky sound as the belt runs around the pulleys...
any idea what causes this @ 13k miles??
can i just fix this by spraying some WD40 on the pulley bearings??
def don't want to go to the dealer here in SB...will have to wait till turkey day to go to Indy and have a proper fix
thanks for ur input
Old Nov 9, 2009 | 09:55 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
WHAT DOES A SQUEAKY PULLEY BEARING MEAN?!?
Old Nov 9, 2009 | 09:57 PM
micropower99's Avatar
2008 Mercedes C300 4Matic
It means your an impatient retard.
Old Nov 9, 2009 | 10:37 PM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
i also have squeaky pullys, only at start up... it goes away after about 30 seconds of the car running...
this is nothing serious though right? no need to go into the dealer??
Old Nov 10, 2009 | 12:41 AM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
same here when it starts to get cold out i hear a squeaky pulley can i just spray some belt dressing?
Old Nov 10, 2009 | 01:07 AM
maninblack's Avatar
1999 210 4matic / 2011 W204 C300 sport
your pulley should be replace under warrenty
Old Nov 10, 2009 | 02:21 AM
rb23lb's Avatar
why its not defective right? probably just needs some lube??
Old Nov 10, 2009 | 02:51 AM
maninblack's Avatar
when it make noise , it can be diagnost as a defective part , should be under mb warrenty
,therfore it should not cost you anything .
please dont use wd40
Old Nov 10, 2009 | 04:28 AM
Jae Duk's Avatar
'09 C63
Under warranty let the dealers handle it. Why put lube on it? If your lube ends up making it worse they'll put the blame on you and void your warranty.
Old Nov 10, 2009 | 09:34 AM
Spec_Davis's Avatar
very true will let the dealer know about my pulley.
