First Oil Change for my C230 4MATIC
My c230 is coming close to 3k, I was recommended to do my first oil change around this time by a friend. This friend told me that the 20k or 1 year interval that MB recommends is insane, especially since I am keeping this car and not lensing it.
Is this true?
Also, does MB have an issue with me taking it to a 3rd party for an oil change? Does it void the warranty at all?
In addition, what brand/type of oil is recommended? and do I need to go to MB dealer to get a OEM MB filter or should the garage I am taking it to have these things?
If anyone can answer these questions that would be great.
Thanks and regards
xwar
IF NOT THEN I WOULD LISTEN TO WHAT MERCEDES SAYS... OR IF YOU DONT LIKE WAITING THAT LONG DO IT A BIT SOONER...
3 MONTH INTERVALS WONT HURT ANYTHING BUT YOUR WALLET... WHETHER IT HELPS THE CAR OR NOT... I DON'T KNOW.
AND YES YOU CAN GO TO A 3RD PARTY... FOR SERVICE A... JUST KEEP DOCUMENTATION FOR WARRANTY PURPOSES.
You are correct in saying that the oil change was done early & MB do not think it is necessary to do the A service early.
My old fashioned thinking is why is the car using oil during this run in period ?. Answer:- It is bedding in the rings to the bore & all other moving surfaces for that matter hence a little more oil passing the rings into the combustion process.
Surely this bedding in results in increased metal in the lubrication system.
But MB think the modern oil & filters will handle this & they are most likely correct.
I usually keep my vehicles for 15 years hence the extra care.
Mb also recommend that the 5 speed auto is sealed for life . No so, as far as my MB service manager is concerned. . He says the oil should be flushed at 60,000 km for long life.
When you do your oil change, do you take it to MB dealer or a 3rd party. Who would you recommend in the Toronto area?
All good so far.
BTW, went with the conventional drain plug method, not the syphon....
All good so far.
