Bent Rim
My question is whether or not it's worth having the rim repaired, or just buying a completely new rim. I drove on aftermarket rims for 2 years throughout the city and have never had a single bend, but I guess tonight my luck ran to an end.
Has anyone had similar problems? I am surprised an OEM rim could bend so easily . .
But yeah, I am not looking for new wheels until spring comes around.
Our wheel repair shops here all do crack detection because there are insurance implications & liability if a repaired wheel fails.
RP
Where did you bend the rim? I was driving on the Belt Pkwy towards the Southern State Pkwy when this happened. The highway is a complete mess and I ended up driving right over a pothole.
Beware of replicas as they are seldom a perfect match in style & colour
In a litigious society like the US I can understand the reluctance to guarantee
nah i got new wheels already, but i did drive on the bent rim for a couple months. but really, it was absolutely unnoticeable.
You call that a pothole-damaged wheel!?!? Now, THIS is a pothole damaged wheel. The BQE, maybe, but the Belt has nothing on roads in Oakland County, Michigan
And, this was too damaged to fix...which my wife was sorry to learn when she brought this home on her E.
These are too far gone to repair as well so I had to get the two pieces replaced. Cost an arm and a leg!
Alexlev: Your rims don't look that bad. I had the same kind of bend on my other car before and I was still able to drive the car around with no problems. As long as there is still a good seal for your tires so the air doesn't come out and you can still balance the tires properly, you should be ok. Though for peace of mind, I would still suggest to have it replaced and keep the bent rim as a spare, just in case. The last thing you want is for the tires to pop when you're driving on the highway. You never know and it's not worth it if you ask me. Hope this helps!
Wide wheels with low profile tyres give MB rims very little protection. If I lived in the Philippines I would fit 16" wheels with 55 profile tyres. There is so much traffic you never really travel fast.
Take a look and think. There are six weights right under where it got damaged. This means the section cast at that point is thinner than the rest.
I'd change the donought spare for this full size wheel, and buy a new wheel to replace the installation.
Cheers,
JV
I was on the interchange between the LIE and William Floyd Expressway. Exit 68. It's as dark as can be at night and there is a nasty edge on the inside with a 8-12" drop off. I was nearly on two wheels WOT and I guess I got too close to the inside so i wouldn't drift into the traffic lane in the William Floyd when BaBoom!!
RP
NEW RIMS!!!
