Lug Nut Size
And where I be able to buy new ones?
Just got some new wheels on and thinking about changing to different lugs.
Heres a crappy cellphone pix.
Speaking with one of my shops, they said that the 28mm length on the Kics bolts should be ok. I was running 25mm ones on my Work wheels. They are tapered, so you will need to run them with aftermarket wheels, they won't work with your stock wheels.
EDIT: Checked MB OEM parts online stated they use M14 27mm lug bolts.
but i just picked up a set of euromag em2's and im guessing i need new lug bolts?
IIRC the stock lug bolt length is 27mm?
So would 33mm length be sufficient? (but not too long?)
also should these be ball seat?
quick response would be appreciated, would like to get the new shoes put on today.
thanks
