Upgraded Wheel Question
Old Jan 17, 2010 | 07:26 PM
autockr989's Avatar
2015 E63S AMG
I have a 4matic
I have a set of 19" TSW Estoril from my old car.
Lug pattern is 5/112
tires are 225/35/19
I'm pretty sure the wheels are 19x8.5 with a 45mm offset. Will they work, won't they work?? Does it matter if all four are the same width?
All anwers welcome. Thanks
I pulled a wheel out of the garage and put it next to the car, (pic below) i dont' want to lower the car and it looks like the wheel sits a bit higher, but not by much.
Old Jan 17, 2010 | 08:53 PM
23wt's Avatar
CLS550 4matic
from the numbers it seems ok. and should be ok for same width.
Old Jan 17, 2010 | 11:13 PM
bigigg's Avatar
14' CLS550
you should be fine..
Old Jan 18, 2010 | 12:51 AM
theonidis's Avatar
W204 AMG PLUS 4MATIC
Wheels should be fine. Tires must be front 235/35/19 and rear 255/30/19.
Old Jan 18, 2010 | 09:31 AM
BEEPbeepZIPtang's Avatar
w204
they will fit but are you SURE you want them on there?
Old Jan 18, 2010 | 09:48 AM
autockr989's Avatar
2015 E63S AMG
hahaha. Most likely no, but just wanted to know i had the option come summer. Actually i really dont' want to ruin the integrity of the ride so i'll probably sell them.
Old Jan 18, 2010 | 11:29 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Well, since your curious to see if they will fit, try putting on one. Just jack up your car, and mount it. You will then know if your have fitment issues or not. The size seems right, but it's a offset issue. If the wheels stick out of the fenders or not. But try it out and see.
Old Jan 18, 2010 | 10:16 PM
Derspeed's Avatar
X3 and 2012 C coming soon
The centerbores are different. MB is 66.5 and VW is around 55 (I think). If the wheels are not hubcentric and will accomodate the larger MB centerbore, you should be fine with rings.
