Alignment problems, Drive train Roughness, Whiny Steering, Whooshing Noise
Old Feb 22, 2010 | 08:46 PM
akbro93704's Avatar
2014 C250 sport
Nearly all of these issues I have posted about within the last year or so, but here I go again just to see if there's any new knowledge...
I have a 2008 C300 with 19k miles that has had alignment problems since brand new:
First, the car came with an off center steering wheel that was corrected, then a continuous problem with the car pulling hard to the right. I had two alignments done at the dealer and one at an independent shop, and none seem to solve the pulling problem...does anyone else have this problem? No matter the road surface the car seems to pull!.
Also, I seem to have drive train roughness at low RPMs, the vibration/roughness seems to occur the most noticeable at around 2k RPM. Dealer says this is "normal".
Third, the power steering seems to be quite noisy, especially while maneuvering in parking lots, lots of whininess and grittiness, if that makes sense.
Lastly, coming from the instrument cluster area, there seems to be a whooshing, leaking air sound when the brake pedal is not in use (it goes away with full pressure on the pedal). It does this no matter if its in gear or not..
Thanks for any info!
PS- I love my car, I'm just a nit-picky person
Old Feb 22, 2010 | 09:12 PM
one sick c's Avatar
c300
have you tried to rotate your tires you might have a tire pull. as for loud p/s i would check for foam in the res. which would indicate air in the system which causes noise.
Old Feb 23, 2010 | 04:31 AM
I_Love_MB's Avatar
S204
I also had this problem. Shown to garage, solved in 10 minutes. Not sure what they did.
Old Feb 23, 2010 | 11:51 AM
whiteongrey's Avatar
'20 Targa 4 DD, ' 18 Volvo S60 T6
I had the PS problem - dealer replaced the PS fluid filter with an updated one and noise gone for the most part. ON an MB one would expect it to be silent though.
Old Feb 24, 2010 | 01:25 AM
C300Kid's Avatar
2015 Carrara White Metallic Porsche Cayman
I have the pulling, none of the other issues though.
