Brake Pad DIY?
Does anyone have a DIY they can share because i can get all 4 sets of pads for about $100 if i order from autozone.com so if i can figure it out myself it will cost much less than the $400 that the dealer wants.
Any help is appreciated!
Les
If that is the case, it seems quite different from the E46.
is that accurate?
If you choose to do your own, some tips: 1) always open bleed valve when forcing pistons back into calipers. You don't want to force old fluid back upstream, 2) Plan to have something the right size to rest caliper on so you don't have to disconnect brake line, 3) use DOT 4+ or DOT 4 LV fluid, 4) don't forget wear sensors (if you have them) and MB anti-squeal paste.
You can get factory OEM discs, pads, supplies, etc. from online vendors like autohausaz. I'm sure Autozone will work but probably not the same quality.
As mentioned you need a few tools such as a box end wrench (9mm) for bleed valve, torx, hex bit or hex sockets for mtg. bolts and a 0-100 Nm torque wrench. You should also determine the min. spec for the disc thickness so you can see if they should be changed.
There's a good Brake DIY at the top of the W210 forum most of which would apply.
Hope this helps you with what's required.
