C300 speedometer in km/h
Old Mar 31, 2010 | 11:51 AM
Canadiac's Avatar
2008 C300 4MATIC
Hey all,
This question has been posed for other models but I cannot find it for W204. I am going to be Canada for a while and was wondering if I can switch the needle speedometer to km/h. The settings through the IC allow me to change the digital speedo and oddometer. Any help is appreciate it. thank you.
Old Mar 31, 2010 | 12:22 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
I think you are pretty well stuck with MPH on the analog dial but the digital KPH should be sufficient until you get accustomed to the comparable speeds.
Old Apr 4, 2010 | 10:33 PM
downtowncanada's Avatar
2012 Mercedes Benz C350 4Matic in Magnetite Black
I would also suggest just using the digital km/h to help you judge your speed. You can work with a Canadian Mercedes Benz dealership to "Canadianize" your vehicle (they actually sub the work out to Canadian Tire) which includes converting the cluster and speedo needle, drilling holes into the front bumper for front provincial license plates (still required in a few provinces), emission check, and safety check. You would typically only go through all that trouble if you needed to import the vehicle into Canada, or a long term visit over 6 months and needed to register the car in Canada. I went through this process to import a BMW into the country.
Old Apr 18, 2010 | 10:59 PM
Canadiac's Avatar
2008 C300 4MATIC
Thank you for the replies. So changing the IC is the only way to convert the analog speedo?
Old Apr 19, 2010 | 07:27 AM
Sully's Avatar
W204 C180 / W176 A45
If you're using an aftermarket GPS, some of them have speed warnings. You could use this as a guide.
Old Apr 19, 2010 | 12:28 PM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
The dealer absolutely will not sub out a cluster change.
