Homelink Opener
RP
The key difference between the 2008 and 2009-2010 homelink mirrors is that the newer versions include an integrated compass. I have COMAND with navigation, so the lack of a compass did not bother me much.
As far as wiring goes, you will not have a problem. All of the mirror's power needs are routed through a single harness, so you do not need to tap/splice any wires. It really is a plug and play modification. You just need to disconnect and reconnect two connectors: power and microphone.
Installation took me about 2 hours because I was going in blind and being excessively careful. Knowing what I know now, I'm confident I can perform the swap in under 5 minutes.
Here's what I learned:
- To remove the top console, slide a credit card in the seam between the console and the headliner. This will push in the retaining clips and the console will drop down on a hinge.
- The hinge is made of plastic and feels pretty fragile, but you can carefully detach the console from the hinge when it's been tilted down far enough. Once the hinge has been detached, let the console hang by the attached wires.
- Detach the mirror's plastic base.
- Disconnect both the power and the microphone connectors.
- The mirror is held firmly in place by two spring loaded bolts. This is done so that if your head impacts the mirror in a crash, the mirror will cleanly break away. To remove the mirror, grab it with both hands and pull it down hard. This will take more force than you'd think, but rest assured that you won't break anything.
- Do all of this in reverse to install the new mirror.
I'm afraid I don't have pictures of the installation, but I'd be happy to answer any questions that come up.
