HELP!! How do I enable Backup Camera in Engineering Mode with Command Update?
1. I've installed the rear view camera, power cable from the camera is connected to the SAM fuse box #71 and added a fuse to it.
2. Black cable from the camera is connected to the ground.
3. The RCA cable is connected to the fakra cable to the Head Unit. Plugged in to the green slot behind.
4. Went to the engineering mode and selected rear view camera, there were two options 1. Not Installed, 2. Installed, i've selected Installed cause there were no srvc or other options.
5. Then turned on Video Aux
6. Then in system setting selected rear view camera and activated by R gear and deselected voice guidance.
But when i put to reverse gear nothing changes in the screen, there were no black screen, doesn't flicker, doesn't show check surrounding.
Please help, any ideas...
You may be experiencing the same problem as me. I never knew how the "add a fuse" worked so I had to troubleshoot a little bit. If you used fuse #71, then that means you took a fuse out in order to insert the "add a fuse" adaptor. Once you have plugged the adaptor in you have to reinsert that fuse that you removed on the top of the add a fuse adaptor. And to complicate things. There was 2 slots on the adaptor where the fuse could go. I had to insert the fuse on the outside slot in order for it to all work. I'll try to post pics of my add a fuse adaptor later today when I get home. Hopefully that helps.
I attached a picture. Hopefully that helps.
I had to go to autozone and buy the add a fuse I showed in that picture above.
i actually have two fuses in the "add a fuse", both slots are filled up, one for the orginal and then the other for the camera.
When I installed mine, I didn't want to "Close the head unit" and put everything back together until I knew the head unit would display video when reversing..... So I connected an old Nintendo to the FAKRA cable and put it in reverse... and once I saw my Nintendo display on the screen I knew the wiring was good to go. Try that out... Maybe with a DVD player using just the RCA-yellow into the FAKRA...?
Just cannot activate the backup camera on the screen. Doesn't black out, or show the camera image, etc. Just stays in whatever mode it is..have tried everything.
can u help me please, i have a comand NTG 2.5 and i don't have the option 'Activation rear view camera by R gear' in my comand settings. But i also can't find the backup camera option in engineering mode.
my question how do i access the camera enable menu in engineering mode?
thanks a lot
BR
