HELP!! How do I enable Backup Camera in Engineering Mode with Command Update?
Old Apr 7, 2010 | 10:13 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
HELP!!
I can't find the backup camera option in engineering mode. I had my command updated by the dealership in october 2009. I saw somewhere in the forum that it is the "first" option in 7.7 HU, but that is "BT CONTACT PATCH". Surely that can't be it, can it? Any help would be greatly appreciated it.
Old Apr 7, 2010 | 10:22 PM
joshg1001's Avatar
2017 E300
on the 7 HU parameters, scroll down to the next few pages by pulling the entire COMAND knob towards the back of the car.
Old Apr 7, 2010 | 10:33 PM
I am Jeff's Avatar
Thanks Josh!! You're a life saver.
Do you know if a blank message should show up when I put it into reverse if I haven't installed the camera, yet have the function enabled?
Did you install your camera via headliner or sill?
Old Apr 8, 2010 | 12:38 AM
joshg1001's Avatar
2017 E300
lol i havent installed the camera yet, but I turned on the function
when I put it in reverse now, I can the black screen that says "check surroundings" but no camera. Thats on the list for the summer.
Old Apr 8, 2010 | 04:09 PM
I am Jeff's Avatar
Interesting....Mine don't say that. Maybe I need to leave it on and leave the car off for a longer period of time
Old Apr 8, 2010 | 05:49 PM
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
Yes, that's what mine said until I hooked up the camera.
Old Apr 8, 2010 | 06:30 PM
joshg1001's Avatar
2017 E300
after you enable it, yes you have off the car and wait a bit before it works
Old Apr 9, 2010 | 05:04 AM
Luisin's Avatar
W204 C180K AMG
Hi, do you know if we activate rear camera ON in Eng menu is sufficient to activate the rear camera?
I have activated this option in my car but when I put Reverse the screen doesn´t work, i only see a black background, no messages showed.
There is somehow to activate the rear camera without going to dealers?
Thanks!
Old Apr 9, 2010 | 11:39 AM
joshg1001's Avatar
2017 E300
that is exactly how you activate the rear camera. I remember there being multiple options within the back camera option menu, and I chose the SRVC.
Old May 12, 2010 | 02:13 PM
deusexisagod's Avatar
w204 c220 cdi
I have installed the camera and set the option to SRVC ....but nothing apears...no black screen nothing...i left the car closed for 10 minutes ufter i set the SRVC....do you have any idea?!Thanks
Old May 29, 2013 | 11:44 AM
marcellen's Avatar
Mercedes A180 W169
Hi guys, where you able to activate the camera via software? Is it strictly needed to go a Mercedes dealer?
Old Aug 20, 2013 | 02:58 PM
Petomaani's Avatar
MB C200 K
I'm also unable to activate the reverse camera. I chose that camera is installed via engineering menu, but nothing happens when I put transmission to R... No black screen, nothing. I cannot see multiple items on engineering menu depending to reverse camera (with SRVC-option etc), just an option if the camera has been installed or not. Please help!
Old Aug 20, 2013 | 03:28 PM
Doa's Avatar
Doa
W205
is the aux video enabled?
Old Aug 20, 2013 | 03:44 PM
Petomaani's Avatar
MB C200 K
I've tried to enable and disable it also, no effect... My Comand engineering menu's HU-category (7) has only 17 parameters when some of users has reported that it should have more than 20... For example, parameter 21 should be the type of reverse camera, but I don't have that parameter at all. Maybe I'm also missing some other necessary parameters?
Old Aug 20, 2013 | 03:53 PM
Doa's Avatar
Doa
W205
i have the pre facelift W204 so i'm with the NTG4 COMAND and i have 4 pages on 7, video aux is on the first one and the reverse cam is on the 3th or 4th page
Old Aug 20, 2013 | 03:56 PM
Doa's Avatar
Doa
W205
btw anyone knows how to call on the video aux when you use it for something else then a reverse cam? i already have a module handeling my 3 cams but i'd like to add some other type of video signal on that port
Old Aug 21, 2013 | 12:24 AM
Petomaani's Avatar
MB C200 K
I'm also having pre facelift W204 (2007/2008) with Comand NTG4, only 2 pages on 7 as I recall - the last parameter was number 17...
Old Aug 21, 2013 | 06:29 AM
Doa's Avatar
Doa
W205
even with the FPL models there are huge differences, i have the last PFL model and came from the first PFL model. i noticed a ****load of changes when i first switched cars
Old Aug 22, 2013 | 03:00 PM
Doa's Avatar
Doa
W205
Old Aug 23, 2013 | 01:12 AM
Petomaani's Avatar
MB C200 K
Here's my HU-parameters at the moment, and reverse camera isn't working - no black screen or nothing else when I put to reverse (automatic transmission):
It's quite different than Doa's... What are BT contact plate- and entertainment-options?
Old Mar 17, 2014 | 08:01 PM
lartiste's Avatar
c220
can you tell me if you find a solution becaufe I have the same probeme you, thank you
Old Apr 1, 2014 | 12:02 PM
Sean PS's Avatar
c200
Having problem activate rear view camera
Have you got your answer yet coz i'm having the same problem with you.
rear view camera is installed, engineering command for rear view camera is activated but when i put to reverse still nothing on screen.
I suspect there is still a power cable which is not connected on the head unit and where should it be connected to, please help..... anyone have encountered this and have solved the problem?
Old Apr 2, 2014 | 02:24 AM
2nice4me's Avatar
2011 E350 4 Matic
Having similar issue and looked though the numerous threads
  1. Camera is enabled, I DO get the "check Surroundings" message.
  2. Video Aux is turned off (tried with AUX ON as well)
  3. tested the camera by plugging it into a TV (using power and ground from car and I get video signal so it cannot be the camera
  4. Tried a different FAKRA cable
  5. Tried the second green fakra input on the command
  6. Turned system car off and on, let the car sit for 10 minutes to allow updating
with no luck, any idea what else i can check? i have another camera on the way but since i was able to get an image on the TV that should not be the issue?
Old Apr 2, 2014 | 03:37 PM
I am Jeff's Avatar
If I can recall correctly, the camera enabled itself after I switched the car on the next day. Are you guys correctly tapping the power to the reverse lamp?
Old Apr 2, 2014 | 09:27 PM
2nice4me's Avatar
2011 E350 4 Matic
I am not tapping the power from the reverse lamp, i am going direct to a fuse using "add in fuse" so the camera is always powered so that should not be the reason.
i will wait and see when i receive another camera that i ordered
