Need pic of location of power steering resovour
I own 2008 C-350 2008 E-350 2005 C -230 Kompressor 2006 FORd F-350 6.0
Cleaning my engine found a black twist off cap not sure what it is. Seems low thou on the dip stip need to know if it power steering fluid. Read the manuel does not say what this black resovour is or where power steering fluid located.I I need to know exact location of power steering i think it is power steering case not sure before i refill it need to be sure
thank You all please send pic of engine compartment and location of power sterring or diagram havnt been able to find pic..
not the exact location, im trying to find it too LMFAO
https://www.getmercedesparts.com/sch.../5/5777202.gif
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Caps
Cleaning my engine found a black twist off cap not sure what it is. Seems low thou on the dip stick need to know if it power steering fluid. Read the manual does not say what this black reservoir is or where power steering fluid located.I I need to know exact location of power steering i think it is power steering case not sure before i refill it need to be sure
thank You all please send pic of engine compartment and location of power steerring or diagram haven't been able to find pic..
And unless there is a leak, there is no reason for the fluid to be low.
2008 C300 4matic Sport
The power steering reservoir is located on the right side of the engine when looking into the engine bay from the front of the car. When you remove the cap there is a dip-stick on it that is labeled. There are two levels marked on it, one is for cold and one is for when engine is hot. Do NOT over fill the reservoir past the marked lines.
