c300 install rear view camera issue
Old Apr 12, 2011 | 09:24 PM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera.
Originally Posted by Garry1104
It's really not that hard to do. Took me a good 3 hrs last weekend to do it. All I bought was a FARKA cable from mid-city and a Sony rear view camera from amazon. Total cost was just $111 but knowing I did everything myself and it worked following the DIY info on this forum was just PRICELESS
Thanks. I am not a very handy person, especially it's my brand new car. If there is a risk of damaging things I'd not do it or have dealer to do it.
I will read DIY more thoroughly.
Old Apr 12, 2011 | 10:08 PM
Garry1104's Avatar
C300 4MATIC
It requires taking out the vent, Comand unit, side sills and the whole trunk liner. Also need to cut/dremel the plastic handle strip and run the wire from the front all the way into the back/trunk area. Took me some thinking and courage to do it. All I can say is good luck!
Old Jun 21, 2011 | 11:33 PM
tcoombes's Avatar
SL55, GL320CDI
Interested in Sony Camera Option
I have read all the posts on installing a rear view camera in a W204 and was thinking a Sony camera would be a good option. What model did you go with? Is it the one with a separate control unit? How did the install go and are you pleased with the results? - Todd
Old Jun 24, 2011 | 06:37 AM
2010_C63_OMG's Avatar
2011 C63 AMG
regarding prewiring: keep in mind that you need at least four wires for your camera: 1) video RCA 2) reverse wire (tapped from backup light) 3) 12V and 4) ground. so your car is probably not "pre-wired."
good camera: go to navvideo.com. and ask for Tony. They have a custom w204 sony ccd backup camera that replaces the license plate backlighting lense. so it plugs right in, no drilling (worrying about leaks, etc). it is kinda expensive at $295 (less $45 with interface combo). but it works well (like OEM) and the location is actually better than OEM since it is closer to center. see my post for pix. after you plug in the camera, look at those great DIY posts on this forum on how to connect the wires.
Old Jun 24, 2011 | 06:47 AM
2011 C63 AMG
there is another post "backup camera for non popup screen". camera install (trunk) is the same, whether you have MMI or not. but interface (up front) is different for MMI vs small screen.
here's the pix.
camera and interface install is probably best done by professional with experience in stereo/camera installs in MBs.
Old Jun 24, 2011 | 06:53 AM
2011 C63 AMG
sorry, i'm a newbie. here's the link to that post, with pix of my install:
https://mbworld.org/forums/c-class-w...up-screen.html
Old Jun 24, 2011 | 10:07 AM
  #32
cactusbob's Avatar
C350 & A200
I've been attempting to find this video connector in the trunk of my 2010, but can't find it. The strange thing is that the back of the Comand unit has a lead and connector coming out of it to somewhere. Does anyone know where the other end may be? I've removed the trim from the trunk lead and nothing
Update - Actually I think the video input goes to the Media Interface. Not that that works either as apparently you need the Media Interface Plus as well as an Ipod Video cable.
I guess it's a choice of either iPod video or backup camera.
Old Jun 24, 2011 | 11:35 AM
  #33
Cartronics's Avatar
Former Vendor of MBWorld
05 CL65 AMG, 07 Ferrari F430, 03 Range Rover HSE
You CAN have it all with our Video In Motion kit (VIM) if you are interested in multiple video inputs AND backup camera.
Old Jun 24, 2011 | 03:33 PM
  #34
cactusbob's Avatar
C350 & A200
Well unplugged the existing input into the Comand and added mine. Simple enough to run the cable over the drivers footwell, and up the A pillar and along the roof lining. Popped straight through by the fuse box I have in the trunk. Now just got to install the camera, and hook it up.
Old Aug 31, 2012 | 04:40 PM
  #35
J.michel's Avatar
Mercedes e350 2010
Originally Posted by white46
i'm also from Edmonton, and installed the back up camera myself.
If you want, pm me, i can give you some heads up.
Hey I read your quote saying you installed the rear camera yourself. WOuld you mind telling me how please. I have a e350 2010.
Old Apr 13, 2013 | 02:12 PM
  #36
Ikester's Avatar
2011 C300 W204 (Pending)
FYI - 2011 W204s have a factory location to install a camera, no need to use the license plate lights.
Mine car doesnt have the camera option but the install location is still there
Old May 31, 2013 | 11:31 PM
  #37
TheBenzAddict's Avatar
C300
2010 rear camera pre wired
Guys, I have a 2010 C300 and I decided to do the DIY rear camera today. I removed the command and guess what.... A green fakra cable was already installed! Now seriously, is the cable pre wired?
I literally took my whole trunk apart and couldn't find it. I even lost a clip (((
Any ideas??
Old May 4, 2014 | 03:55 PM
  #38
Csc300's Avatar
W204 2008
Heyy i know u posted this long time ago.. But i need some help in installing a rear camera on my c300 if possible
Old Feb 18, 2019 | 10:28 AM
  #39
dc1989's Avatar
2014 C300
DID YOU EVER GET IT SET UP?? I HAVE A 2012 C300 AND I AM LOOKING TO INSTALL A REVERSE CAMERA AS WELL.
PLEASE HELP.
Old Feb 18, 2019 | 10:29 AM
  #40
dc1989's Avatar
2014 C300
NEED HELP WITH MY REVERSE CAMERA INSTALL ON 2012 C300 (W204)
HELP!!!!!!!!!!!!!!!!!!!!!!
