Suspension Technical Help, Please?
The rear is another story and I need expert advice! On further research, the tech here realized that the entire rear sub-frame has to be dropped, including removing springs/shocks, which is about 3-4 hours in the flat rate manual at around $100/hour
! Although the shop manual says the sub-frame should be dropped, it looks like if one rear wheel was removed, the bar might be able to be snaked out cross-car, and new one maybe installed the same way. Has anyone tried this or had any experience changing the rear anti-sway bar without dropping the rear sub-frame? Vic, Michael, anyone, please? The rear bar is at the shop, waiting, while we figure out how to do this without so much spent on labor.
