- Mercedes-Benz C-Class: Sound System Modifications
Overview of popular modifications to customize your Mercedes-Benz
Browse all: Interior Guides
DIY: C300 Amplified Subwoofer Install
Long story short, run the power cable to the battery on these newer models...
Oh and i agree that its much easier to just get the speaker outs at the radio... (unless you have the amp in the back in which case you can get them there...)
Sorry for the poor pic it was off my phone
I'm trying to run my re-Q to the best possible source. I may just take the headunit out fwiw. I want to do it right the first time around. Shouldn't be too hard to run RCA's to the rear, I'm hoping.
http://www.crutchfield.com/p_142LOC8...evel+converter
Install a Focal Bus 20 active sub in the rear trunk in my S204. I have the battery in the rear trunk, what will be the best to do:
Power from battery or from sam module?
And where will be the best place to pick up power for the remote cable:
Is there any connections from the Command to use?
Or do I have to use power from the lighter?
I have installed my Focal Sub, and I used a hi to low converter with remote control signal. Since I have a diesel car, I have the battery in the trunk, and just pulled power from the battery.
It works very well I think, with an increased sound performance.
Andy
I am about t install a sub amp and sub box tomorrow and I was wondering if you or anyone else out there who's gone before me remembers if it was difficult to remove the factory HK sub from the rear deck and if the + & - cables are clearly marked? From the pic TRDRunner posted the left side has two different colors and the right side looks to have the same color for both.
Nate
I'm going to use Audiocontrols new LC2i instead of a standard LOC, I've heard great things about it.
I was talking with a guy on Caraudio.com who installed a sub in his C300. He said he wasn't happy with the output so he cut holes in the metal behind the rear seats, which made a big difference...according to him. Here's what he wrote:
"I didn't cut plates in the rear deck, but moreover make "ski" holes in the plate of steel behind the rear seats. several circular holes with a hole saw and a large squared off hole where the armrest flips down for skis. The black plastic shroud behind the fold-down armrest pops right off so you can get access to it.
As far as obtaining a signal for amplifiers goes, I used an OEM integration unit. Of course it keeps absolutely every steering control, phone, etc useful. Which I HIGHLY recommend using way over a LOC."
Because some guys said should never disconnect the battery on Mercedes, when you reconnect it the engine won't start and many error appear on dash....
