Sunroof Noise?
Old Jun 22, 2010 | 12:38 PM
jctevere's Avatar
2012 C250 Coupe
Sunroof Noise?
After searching for anyone else with this issue or a fix for it, I came up empty handed. About 2 months ago (when the hot weather started to roll in) every time I would tilt my sunroof open. I would get some horrid noise that sounds like rubber rubbing with more rubber? Almost like a really loud rumble. I was wondering if anyone else has experienced this, and if it si normal. Or if I should take it into MB and have it lubed up, or could it be something more major?
Old Jun 22, 2010 | 01:31 PM
albertb's Avatar
2010 E550
You're not the only one. Mine makes the same noise but I haven't had a chance to look at it or take it to the dealer to fix.
Old Jun 22, 2010 | 07:56 PM
LaicepsYdobon's Avatar
2011 E350 Sport 4Matic - P2 & Drivers Assist / 2010 C300 Sport 4Matic - P2 / 2013 Porsche Cayenne S
Its very likely that they just need to be lubed up. If it's dry rubber rubbing against dry rubber then it could flake and tear which would mean the rubber sealant needs to be replaced and that it going to be expensive. Use the A/C until you have time to take it in to the shop. Pretty sure they will just lubricate the rubber for you while you wait.
Old Jun 22, 2010 | 08:43 PM
Will38's Avatar
2008 C300
Wow seems like alot of people has that same issue, just bring it to the dealer and let them fix it. :P
Old Jun 22, 2010 | 10:33 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Squawk
It appears to be unpleasant but normal since most hear the noise (including me) and it does occur when the roof is hot.
If there is a fix for this, we all want to hear about it.
Old Jun 22, 2010 | 10:50 PM
Distalero's Avatar
C 300
There is a fix. Had the same problem, dealer took care of it during the A service which was last year, haven't had a problem since. The service sheet breakdown stated lubing the sunroof was performed.
Old Jun 22, 2010 | 11:27 PM
08w204's Avatar
2008 MB C300 Sport (Mars Red)
I've had the sunroof lubricated three times but the noise still comes when the (pano) roof is hot... I hope nothing is going to break but willing to bet it's a design problem and not a maintenance problem.
