AZN Optics 5W5 Canbus LEDs
Old Nov 18, 2015 | 04:44 PM
  #976
vipsa's Avatar
'09 C350
Awesome. I like the sound of the V6 with the CREEs. I'll probably wait for them to come out.
Thanks Mike, always thorough with your products.
Old Nov 23, 2015 | 12:12 AM
  #977
manny26's Avatar
2010 Mercedes c250 4matic
Interested in the 6000k HID lights for w204 , with 2 sets off bulbs for eyebrows to match the hids, wanted them close as possible to the LED DRL lights the 2011 w204s have , or would that be 5000k?
Old Nov 23, 2015 | 02:21 AM
  #978
AZN Optics's Avatar
SPONSOR/MBworld Guru
Hi Manny. If you're looking to match the LED DRL, you'll want 5000K. You'll want our H7 Morimoto HID conversion kit and a couple sets of our 194 V5 wedge LEDs.
You can purchase directly from our website here:
http://www.aznoptics.com/index.php?m...products_id=65
http://www.aznoptics.com/index.php?m...products_id=95
Or if you want, PM or email me (aznoptics@gmail.com) your PayPal or Venmo account info and we can send you an invoice directly
Old Nov 29, 2015 | 11:25 PM
  #979
manny26's Avatar
Licence plate
What color LED lights do
You have available for licence plate ? Do you have any colours that are close
To the stock yellowish colour or just 5000k and up?
And for the high beam bulbs do you have any bulbs available for them that will match the new 5000k HIDS I
Got of
You ?
And by the way they look great just installed them
Old Nov 30, 2015 | 12:35 AM
  #980
AZN Optics's Avatar
Got of
You ?
We do have 4300K which is a pale white color that will probably meet your needs:
http://www.aznoptics.com/index.php?m...products_id=96
As for H7 High beams, we do have HID high beams which would match the color if interested in doing that.
Old Nov 30, 2015 | 11:38 AM
  #981
manny26's Avatar
Do you have just the h7 bulbs or is it gonna be a whole HID kit for that also ? And the pale white LED lights are probably brighter and nicer then the stock halogen licence plate lights right?
Old Nov 30, 2015 | 12:41 PM
  #982
AZN Optics's Avatar
So you're just looking for halogen bulbs for your high beams then? If you're just looking for a simple improvement on color, take a look at Philips Diamond Visions. Those are as close to white as halogen bulbs can get. They are not the brightest bulbs though, but will give you the improved color.
And yes, anything will be better than the stock halogen plate bulbs.
Old Nov 30, 2015 | 08:05 PM
  #983
manny26's Avatar
Yeah that's what I mean, anything close to the 5000k HIDS , I only have high beams on sometimes anyways , but for when I do Atleast they can match . And yeah might place order soon thanks
Old Nov 30, 2015 | 08:07 PM
  #984
manny26's Avatar
5000K HID BY AZN
Old Dec 8, 2015 | 09:22 AM
  #985
alexfirth91's Avatar
2009 Mercedes-Benz C300 4Matic
Had problems with flickering and the inner LEDs don't illuminate any resolution recommended?
Old Dec 8, 2015 | 11:37 AM
  #986
Skyline45's Avatar
2016 GLE450 AMG Coupe
Same here, but AZN Optics replaced them with no issue. However, now a third bulb from my original order has now gone out as well. I'll probably be moving back to normal bulbs myself..
Old Dec 8, 2015 | 11:40 AM
  #987
AZN Optics's Avatar
Pull it out and try reseating it to make sure you have good contact point. Sometimes road vibrations and bumps can shift the units. If that doesn't work, shoot us an email or PM with a pic of both sides of the unit. Could just be a faulty component or damaged somehow.
Old Dec 8, 2015 | 11:41 AM
  #988
AZN Optics's Avatar
This was a bulb from the original or the one we replaced? Wonder if there was a component issue from the first batch of that you were a part of.
Old Dec 9, 2015 | 12:04 PM
  #989
transamnut's Avatar
2018 E400 4Matic Coupe
Hello!
AZN Optics is proud to present to the MBWorld community our line of 5W5 LEDs for the w204 model.
LED Description
These are super bright 360-degree shine LED bulbs with built-in load resistors,specially designed for European vehicles such as Mercedes, Audi, Volkswagen, Porsche or BMW, etc.
These OBC Error Free T10 Wedge LED bulbs will replace the stock 168, 194, 2825, 2821 or W5W bulbs.
The length of this T10 LED bulb is approx 1.15 inches. Since this T10 LED bulb is slightly longer than the stock wedge tungsten bulb, so buyers must make sure the this T10 SMD LED bulb can fit into the housing before buying, but I have verified that they will fit in eyebrows, sidemarkers, and license plates. They are kind of snug and sit right up against the lens housing in the sidemarkers and plates, but through my testing, no damage has been caused, but it is up to the individual buyer to determine if this is fine with them.
Each LED bulb equips with 8 pieces High Power 1210 SMD CREE LED Chips, with built-in Load resistors. If you're not familiar with CREE, they're basically the best on the market. Most professional detailers prefer to use CREE LED chips for their lighting source for defect detection due to the high quality output.
Reviews
I have conducted a series of long tests and these LED bulbs light up perfectly and stay on error-free with no flickering. You can find reviews for these LEDs here:
https://mbworld.org/forums/c-class-w...ew-thread.html
Brief history on W204 eyebrows
Like that hair hair regrowth commercial, I'm not just the owner, but also a client! For those who know me, they know that those in the w204 community searched long and hard for high quality LEDs specifically for our eyebrows that could handle the unique properties of that location. All other LED makes out there just plug their LEDs in and if they turned on, called it a day. What they failed to see was the voltage shift while driving which caused LEDs to shift color from white to blue, and blue to purple! Also their circuitry couldn't handle the increased voltage and caused the LED to prematurely fail and in some cases, damage the connector! I worked with the engineer on these LEDs to specifically handle the unique properties found in 204 eyebrows and so far, the results have been outstanding. Many out there are now currently using these and loving them.
Technical Specs
Led Quantity: 8 diodes pc 3528 smd
Lamp Socket: wedge
Emitting Color: 5000k white, 8000k blue
Available Voltage(V): DC12/24V
Luminous intensity:white 65lm
Average life time: ≥ 50,000 hours
Pricing and Payment
1 set (2 LEDs) of 5000K LEDs will be $18
1 set (2 LEDs) of 8000K LEDs will be $19
2 sets of 5000K LEDs will be $35
2 sets of 8000K LEDs will be $37
3 sets of 5000K LEDs will be $50
3 sets of 8000K LEDs will be $53
4 sets of 5000K LEDs will be $65
4 sets of 8000K LEDs will be $70
PM me if you wish to purchase more than 4 sets.
I accept Paypal payment, cashier check, money order, or personal check, but for personal checks, will need to wait till clear before ship. Oh, and shipping is FREE! (to continental US and Canada). PM me if you're in some other country and I'll get shipping quote to you. I ship USPS first class to cut your costs. Tracking option is available at an additional cost. For you Canadians, just as an FYI, Canadian Customs is retarded and like to hold your shipment so expect some delays.
If you pay via Paypal, please send payment to michaelctao@hotmail.com and PLEASE include your username, address, quantity, and color in your payment message to ensure no issues.
LED Recommendations
If you're on stock xenons, I'd highly suggest the whites as that will match best with your setup. Your eyebrows require 2 LEDs per side, so you need a total of 4 LEDs or two sets for eyebrow conversion. This is a simple DIY and makes a dramatic difference.
Other Model Compatibility
These LEDs have been fitted to w211 city lights and w209 black series city lights and work great! If your model isn't listed here, message me for super special cut rate prices to serve as my test fit vehicle!
We here at AZN Optics look forward to bringing you high quality lighting products and wholesale prices. Please feel free to PM me with any questions!
Blue (note: I'm running 8000K HIDs):
White (note: I'm running 8000K HIDs):
Both (note: I'm running 8000K HIDs):
__________________________________________________ ______________
Good morning, I would like to purchase two sets of 8000k bulbs for my 2010 C300 (eyebrow lights). My first attempt to put LED's in that location worked well and I was very happy with the "bluish" look, but after a while I started to get the "flickering" and even bulbs that are completely off once in a while. I, like many others, I went the ebay route and it seems you get what you pay for. I want bulbs I can rely on; I've learned my lesson and I will spend the extra money. I will send via paypal. Let me know. Thank you.
Old Dec 9, 2015 | 02:29 PM
  #990
AZN Optics's Avatar
We can definitely get you set up proper. Just PM (or email at aznoptics@gmail.com) us your PayPal email address and we can send you an invoice.
Old Dec 13, 2015 | 08:35 PM
  #991
manny26's Avatar
Just put in the licence plate lights today also look nice 4300k , why are the designs so hard to fit into the plug ? Have to real get it in there pretty hard lol. What size are the interior bulbs ? 2 in the front and 1 in the back I think ?
Old Dec 13, 2015 | 09:22 PM
  #992
AZN Optics's Avatar
Limited real estate and trying to pack in as much tech as possible. Only place we could put the resistor was at the base. We are toying with some alt designs to make it looser.
Front dome uses 1 set 194 wedge, rear dome uses a single 41mm festoon. There are also two 194 wedge bulbs in the rear dome as map lights.
Old Dec 13, 2015 | 09:46 PM
  #993
manny26's Avatar
Are the interior ones a different type of fit ? Looser ? And what do people mostly use 4300k or 5000k? 4300 would probably look more OEM I think . I wanna get the full interior light package including the footwell
Old Dec 13, 2015 | 11:00 PM
  #994
AZN Optics's Avatar
Most go with 5000k for interior. Several even go for 8000k for the slight bluish hue. We do have plasma panel for front dome in 5000k if interested. 8000k uses V3 model so normal fit.
Old Dec 13, 2015 | 11:41 PM
  #995
manny26's Avatar
What's a plasma panel ? I'm gonna probably be getting LEDS for the interior also , keep the stock look though so probably not gonna be going blueish
Old Dec 14, 2015 | 12:38 AM
  #996
AZN Optics's Avatar
Was a special order run we made for a few customers that we still have stock of. From what you're saying, it sounds like 5000K would be the better option for you.
Old Dec 14, 2015 | 12:44 AM
  #997
manny26's Avatar
Those look pretty nice how do they mount into the front dome lights ? And how much for a full interior kit? I got the hids and licence plate lights to of you so hopefully can hook up a good price
Old Dec 14, 2015 | 12:54 AM
  #998
95Sinned420's Avatar
2016 S550
Same here. They're great when they are working, quite annoying when they start to fail. I got tired of replacing them because the driver side isn't the easiest to reach. So I went back to normal bulbs--hate the color, but
Old Dec 14, 2015 | 12:55 AM
  #999
AZN Optics's Avatar
They mount via 3M double sided tape on the backside (included). Putting together list and will PM to you
Old Dec 14, 2015 | 01:25 AM
  #1000
manny26's Avatar
Any pics of how the LED look in the red housing for the trunk ? And door lights ?
