Opinion on Wheel Spacers
Old Jul 29, 2010 | 07:45 AM
jlb0125's Avatar
2010 C350
I would like to hear some opinions as to wether you have or would add wheel spacers to your vehicle. I have the staggered 17 inch AMG rims, which I like, but would like for the tires to be flush with the fender. The drop with the Sport suspension is fine for my taste, so I do not have any plans right now to add springs.
Thanks in advance.
Old Jul 29, 2010 | 08:02 AM
bigigg's Avatar
14' CLS550
With 17" wheels and stock suspension, personally I wouldn't bother.. But if your looking for a more flush look, then yes spacers will help.. I'm actually in the market for 5mm spacers for my rear wheels.. Make sure you get hubcentric..
Old Jul 29, 2010 | 10:57 AM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
The more you add in spacer distance from the fulcrum point the greater the torsional load on the bearing set. Get the wheels designed for your vehicle with the proper backspace. By pushing a small wheel to the outside you increase the load on the bearing which may lead to premature wear and/ or failure.
Old Jul 29, 2010 | 11:46 AM
jlb0125's Avatar
2010 C350
Thank you both for your comments. ejsheltra, do you think that 10MM upfront, and 5MM in the back will put a lot of load on the bearings?
Old Jul 29, 2010 | 07:09 PM
E92-Lighting's Avatar
Former Vendor of MBWorld
BBS LM's 18's + Kics
flush wheels look much better than sunk wheels
