Broken doorhandle...
Old May 11, 2016 | 07:03 AM
  #51
NewtwoMB's Avatar
MB C220 Sport W204, 18" AMGs, Grey lthr, xenons, p'ktronic, HKardon, Comand nav.
Hi, Have had this issue with my late 2008, and with VWs, Audi A4s and other cars in the past. No biggie.
In my case I was lucky that the internal metal rod had just popped out of the plastic clip, and I was able to just relocate it again. But took additional measures to ensure it doesn't happen again. Surprising really considering that the back door internal lock has probably only been operated less than 10 times in the whole time I have had the car (from new). Youtube came to the rescue for me.
Old Jun 30, 2016 | 11:29 PM
  #52
cjs322's Avatar
C300
This happened on my 2010 C300 passenger side door two years ago and now on my drivers side. Mercedes Benz doesn't want to stand behind this as bad workmanship. It is completely ridiculous, it should be fixed\replaced no questions asked, it is a poor design, poor testing and cheap materials. Why buy a Mercedes? I'll never buy another. Complete embarrassment.
Old Jul 1, 2016 | 07:33 PM
  #53
Uncle's Avatar
2010 C300
MB should design a repair kit; which would consist of a new lever, pin, and connector. Cost would be about $5.00 to them. Sell it for $50.00 .
This is another item on these cars that should not fail at the rate they do. It says a lot about their suppliers.
Old Jul 8, 2016 | 03:19 AM
  #54
itsrichierich's Avatar
'06 C55
http://www.agatools.com/door-lever-repair-kit
Anyone try this?
Old Jul 9, 2016 | 09:55 AM
  #55
Uncle's Avatar
2010 C300
That looks like a ideal solution to me.
Old Aug 5, 2016 | 08:09 AM
  #56
PortC43's Avatar
2018 C43, White with Red interior
Originally Posted by itsrichierich
Wondering that myself. From what some others have said, a simple drilling of a hole and some wire/wire tie etc does the trick ? Havent taken my door panel off yet to check it out
Old Dec 5, 2017 | 11:00 AM
  #57
Shmatko22's Avatar
C300
I have seen the handle being for sale for about a year now.
It does require bit of work to replace it.
Definitely better then ordering a color matching panel from the dealer.
https://cdn.shopify.com/s/files/1/21...46985993934495
Old Jul 10, 2018 | 11:30 AM
  #58
Kotat90's Avatar
2004 Mercedes Benz C240
Door Handle help
Originally Posted by cjmarshall
I have a PDF document with pictures for this but it wont allow me to upload it.
Hey cjmarshall, I know its been a while since this post, but would you be willing to email me that PDF with the instructions? Email: youngballer101@yahoo.com
Old Aug 13, 2018 | 02:10 AM
  #59
rlmesq's Avatar
2018 440i (but my wife has a 2010 C300)
The repair kit is now available on Amazon. I just got one for my wife's car. It broke about 18 months ago and I was able to stick it back together with JB Weld epoxy putty... but now it's broken again. The epoxy held, but the lever broke in a different spot.
As a new member, I don't think I can post links, but if you search Amazon for mercedes w204 inner door handle repair kit, you'll find it. It's a bit of a PITA to take the door panel apart, but it's far cheaper. I used a wood chisel and rubber mallet to shear off the plastic welds.
Old Jun 1, 2019 | 03:49 PM
  #60
Demetrios Tom S's Avatar
c 250 2013
that happen to mine c 250 2013 amazon I got it in one day 44$ I spend 70 labor it took one hour to fix it
Old Jun 1, 2019 | 05:05 PM
  #61
rlmesq's Avatar
I was disappointed that the kit didn't include the little while connector that attaches the cable to the handle. I found it on the parts diagram for a later year MB. It appears they started offering parts for the door instead of making you buy the whole panel.
Old Jun 20, 2019 | 03:34 PM
  #62
Mink Jin's Avatar
Mercedes c240
My door handle just happened to break yesterday. Glad I checked to see what other options there were then breaking the bank at the dealer. Did you hire someone to repair it or did you repair it yourself? Anyone in the LA area that can give a solid referral??
Old Aug 24, 2019 | 02:43 PM
  #63
J Branche's Avatar
C250 W204
My door handle broke 5 days ago. Checked online and found replacement handle on Ebay under $30. Just has handle, screws, washers, and pin to hold handle into panel, No instructions.
Bought the Auto trim removal tools, torx tools, and wood chisels (more about this in a moment) at Harbor Freight for under $25.
Google IE amazon.com w204 door handle replacement, scroll down to the video, How to replace your interior door handle.
Or Google IE w204 door handle replacement, Youcanic, Mercedes-Benz Interior Door Handle DIY FIX W204 should be first result for written step by step instructions.
If you are careful and take your time it is only 1 1/2 hours work, better than buying a new door card.
Step 3, Top Tip. Removing ALL the melted tabs took under 5 mins. Get hammer, use 1/2 inch wood chisel as flat and level
as possible and tap the bottom of the melted tabs, letting chisel cut the tops off. I swear when they pop off in 5 to 10 secs a piece you will be thanking me.
Step 5, The door handle cable clip is a real pain to get off Old handle. I used channel locks and needle noose and small flathead screwdriver to tear the old handle from around the clip.
Lastly if you are using the cordless drill/screwdriver to install screws set clutch to one of lowest settings and then
hand tighten all screws to finish.
Hope this helps others and saves them some money better allocated to other things.
Old Dec 8, 2020 | 09:04 AM
  #64
Peter Gyscek's Avatar
2011 C300
can you email me that pdf? ptwop@aol.com
Old Feb 28, 2022 | 08:23 AM
  #65
Brad2012C200's Avatar
2012 C200 Estate
And another one 🙄
Same issue brings me here. Driver's door handle disconnected/not working - assume broken.
It's obv a well known problem now and there seem to be various replacement kits on line and you tube 'how to's'...
Just wondered if anyone had purchased a kit recently and if so where from (link for ref pls) was it quality / worth the money etc?
Many thanks.
B.
Old Feb 28, 2022 | 07:23 PM
  #66
MrNubin's Avatar
C250 E350
it can be replaced without changing the entire door panel, i did it on my 2012 its not real hard but you need some patience removing the panel backing to get to the handle there are replacement kits for the handle online for about30$ the entire panel will cost u around 1K. There are a few you tubes on how to do this
Old Dec 22, 2023 | 02:29 PM
  #67
knowyourlimits's Avatar
C250
Door handle fix is expensive!
The handle on my wife’s 2013 C250 sport sedan broke this week. Dealer just said it’s going to be $2500. Add a rear light that also needs to be replaced at $600 and I’m starting to question if it’s time to sell it. It’s a super clean red car and the dealer says it’s one of the cleanest they’ve seen at 10 years old. She loves it. The loaner she brought home sounds like a Toyota.
Old Dec 22, 2023 | 04:11 PM
  #68
TimC300's Avatar
I just took a quick look at they have used door panels on ebay for $200 shipped. Thats not even looking for a good deal.
Old Aug 23, 2024 | 01:48 PM
  #69
Jespaz's Avatar
Mb 320
can you send it to me? Jnocerin at gmail ?
Old Aug 23, 2024 | 06:30 PM
  #70
Demvang's Avatar
2011 C300 4Matic Sport
The inner door handle will eventually break. It might break sooner if you pull it hard I replaced it earlier this year. Buy $10 kit + your time = save $$$.
Old Aug 23, 2024 | 06:58 PM
  #71
meazz1's Avatar
C250 2013
I just replaced the driver side door handle with a $20.00 handle from Amazon.
Some of the screws did not secure snug so I used a hot glue gun and riveted them.
Old Aug 23, 2024 | 08:11 PM
  #72
Demvang's Avatar
Meazz1, it’s only
9.99 9.99
@ Amazon Ebay is cheaper.
Everything around the driver will have issues because it’s the most abusive area, for me … torn seat, peeled control buttons, door lock, door handle.
Old Aug 23, 2024 | 09:59 PM
  #73
meazz1's Avatar
C250 2013
Originally Posted by Demvang
Meazz1, it’s only 9.99 @ Amazon Ebay is cheaper.
I bought 3 different handles from Amazon, $9.00 ish was the cheapest and $29.99 was the most expensive one. I ended up keeping the $19.00 one I believe. I just wanted to make sure the chrome /silver color matches the old one.
