W203 and W204 C180k the same engine?
Old Sep 15, 2010 | 06:31 AM
rs2002's Avatar
2009 CLC 180k Sport
Hi all
Could you enlighten me and tell me if the W203 C180K coupe and W204 CLC use the same chassis/engine/gearbox and most importantly catalytic converter?
My wifes 2009 CLC has developed a fault with the catalytic converter and Mercedez are refusing to cover under warranty (stating it has a dent in it, likely a rock or kerb). MK customer service hopeless; down right rude and snooty.
I'm after a used cat however there seems to be no W204 180k Cats around, but an abundance of W203 C180K cats by 3rd party manufactures/breakers supplying used OEM.
Any help apprecaited.
Kind regards,
Raj
Old Sep 15, 2010 | 07:54 AM
theonidis's Avatar
W204 AMG PLUS 4MATIC
CLC has the engine of the w203 model not from w204 C-class. In your case i would install a sport metalic converter 200cpsi.
Old Sep 15, 2010 | 11:46 AM
rs2002's Avatar
2009 CLC 180k Sport
Thanks for the reply theonidis - would you or anyone be at levy to tell me that part number for the cat for the w203 c180k and the w204 clc 180k? I phoned Mercedes Benz and they refused to give me a p/n.
If someone can PM me this it would really be appreciated.
Also you say to put a 200cpsi cat on, do you know of anyone who can supply (presume you mean aftermarket)?
Cheers
Old Sep 15, 2010 | 12:12 PM
Amaxm's Avatar
(internet + google)/search = answers
http://www.hjsna.com/products/HJS-Hi...9095-0092.html
