Need help figuring out tire size
Old Sep 27, 2010 | 01:21 PM
EricG.'s Avatar
2011 C300 4matic
Hey guys, I need some help figuring out the right size tires to put on these rims (c300 4matic). I'm thrown off because I expected them to be 8.5" and 9.5" respectively instead of 8" and 9".
http://cgi.ebay.com/ebaymotors/ws/eB...ht_5391wt_1167
Thanks!
Old Sep 27, 2010 | 01:32 PM
TheDarkSide's Avatar
C300 4MATIC (w204)
Thanks!
On the 8.5" recommended width is 255
On the 9.5" recommended width is 275
Old Sep 27, 2010 | 01:37 PM
EricG.'s Avatar
2011 C300 4matic
So should I stick with that for the 8" and 9"?
I was thinking about going with 245/40-18 and 265/35-18 but I'm just confused as hell.
Old Sep 27, 2010 | 01:48 PM
C300 4MATIC (w204)
I would recommend 235-40-18 on your 18x8" but running 245's shouldn't be an issue. The 265-35-18 is perfect for the 18x9".
Your biggest factor is going to be your offset. The offset is what will make or break the look you're going for.
Old Sep 27, 2010 | 01:54 PM
EricG.'s Avatar
2011 C300 4matic
I appreciate your help! The offsets are coming 48mm and 50mm. I think I'm going to take your advice on the front tire size. I'd just like the wheels to look biggest.
