groupbuy on POWERCHIP ecu tune
#51
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
I did my Powerchip ECU upgrade exactly one year ago on my car. From what they told me I am up about 20HP, which is what it feels to me. They told me in the unlikely event of a reflash they would redo it for $100. It does require opening up the ECU. Best $600 I spent on the car. I have the active handling package which allready has a more aggresive shift program and the ecu tune make it rock thru the gears. MY gas mileage has gone down though.
does it void the warranty?
thanks n advance
#52
aigh so if you guys are gonna show up on sat they're gonna open the doors at 10 for us see yall there!!! thanks again powerchip for the sick *** price
1. ulovemybenzo c350
2. qqwweerrttyy c350
3. david c230
4. david 325i
5. sd202 c280
6. Tank C350
7. sooplussssh c300
3. david c230
4. david 325i
5. sd202 c280
6. Tank C350
7. sooplussssh c300
Hell ya im in!
guess you guys dont care too much about lowering gas milage though, right?
any idea by how much?
#53
3. david c230
4. david 325i
5. sd202 c280
6. Tank C350
7. sooplussssh c300
8. rb23lb
3. david c230
4. david 325i
5. sd202 c280
6. Tank C350
7. sooplussssh c300
8. rb23lb
#55
2014 Ghibli S Q4 & 2008 C350
Hey guys,
Attached is a sample dyno done of a C350, due to the interest we've received we are making a month long sale for MBworld members. The most common response customers have after installing a powerchip is that the car feels smoother and "It's how the car should've come from the factory."
If you have specific questions please call the office we'll be happy to answer your questions.
Please sign up at the groupbuy signup sheet located here:
http://www.bimmertech.info/group-buy...er-2010-a.html
You can also pay online at that link if you choose and we will process your order.
#56
99 W210 E55
#57
99 W210 E55
#63
Powerchip said they'll be having this deal for a month for mbworld members correct? I may do this at the end of the month......It's so tempting D: And I'm like 20 minutes away.
#65
2009 C350
for those of you who are mailing your ecu-s in, here's a quick how-to on removing your ecu. It literally takes less than a minute and requires minimal intelligence. dont blame me tho if something does break =P
pop the hood (photos from Sanjuro Makabe's thread)
![](http://img515.imageshack.us/img515/1377/62624662cg9.jpg)
pull the bottom part of the engine cover out. just carefully pull it and it will pop out easily.
![](http://img515.imageshack.us/img515/9672/20646779gq1.jpg)
then there are 3 tubes you need to disconnect: the two intake tubes, and the black rubber tube right below the left (passenger side) silver stripe on the cover. they'll all come off with a little bit of wiggling and pulling.
then, (video took today)
http://www.youtube.com/watch?v=hEm_CPp0ogs
pull the top half of the cover out, disconnect the 2 plugs that connect to the ecu, and pull your ecu out
#66
guys, what are the chances that something in the engine gets messed up and the dealer trys to blame it on your powerchip mod... does it void the warranty most likely?
#67
99 W210 E55
#70
2008 Black Out C350 Saks Edition / 87 VW GTI
The guys from powerchip said I should be around 300hp with the exhaust and filters.
Last edited by tanktube67; 10-10-2010 at 03:49 PM. Reason: POSTING UNDER THE INFLUENCE OF ALCOHOL
#75
99 W210 E55
In standard form, the C300 produces 228 hp and 222 lb.-ft.
Powerchip has a range of chips to suit your car, which can increase it's power to 246 hp, and it's torque to 239 lb.-ft.
jhhahahhahahhahahhaha dooooo ittttt
qwerty , tank, skyy, and soplushhhh i kno these guys are lovin every second of it![drive](https://mbworld.org/forums/images/smilies/driving.gif)
cant wait for my ride to come out the shop and get mine done![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
