New 19' Rims need springs?
MB C-300 Sport 2009 Manual Black XPIPE+Exhaust
So i got rims from one of the guys on the forums installed them looks good the car is almost complete but now i feel like I need springs since they do rub sometimes on hills or dips any suggestions on what springs and how much?
it only rubs if im going too quick and its a downhill coming up on an uphill thats all if I get springs should i get sport springs I dont want to lower it it will make it worse. I dont know much about sport suspension or springs.
c350
I had same problem, but it was rubbing on the inside felt wheel well, just pound it out with a hammer, as the back of the felt is aluminum. Super Sport or coils!
W204, W220, S15 Silvia
got it thank you for the help Im actually surprised that you guys answered over 200 people looked at the post and only you two replied I appreciate it
hahhahahha dont u hate that... anyways find out where its rubbing if its the fender u might wanna get em rolled or if its rubbing against the plastic on the inner side of the fender maybe a spacer will fix that
thank you for the reply agreed! the thing is it only rubs if im gong fast on a bump like over 50MPH or over a dip is that normal?
C350
bro., i'm new here.. i'd like to know abt the c300 or 350 in one of ur profile pics.. are those 20" or 19" on that car..??? cuz' now i'm lowering mine 1.7" front n' 1.8" rear.. n' i wanna put 20" lexani lx 15s wth negative camber degrees.. do u think it might work..?? pls advice.. thanks..
SPONSOR/MBworld Guru
kirill, as others have stated before, you're rubbing cause those wheels have the wrong offsets. You can see from the pics that they sit just a bit too far out and when your springs compress, you're probably hitting your fender. If you don't want to get new wheels, first thing you should is find out exactly where they're hitting. If it's the inner lip of the fender, you can cut that part out if it's the front, roll if it's the rear. If that doesn't work, you can also get adjustable camber arms and induce some negative cambering which can help it just tuck it in on spring compression. Lastly you can get some coilovers with adjustable damping that can stiffen the bounce without dropping it lower.
they guy i bought it from had it on his c350 and did not have problems its the same offset
i asked he said "My car is lowered with H&R sports springs and wasn't rubbing" so maybe I need springs the car stock is not made for 19's most likely however...i think it only rubs on the left front tire but it dose not sound like a rub it sounds like it hits plastic
