Prototype locking bolts (limited quantity)
Old Oct 20, 2010 | 05:32 PM
Staff@RPM's Avatar
Former Vendor of MBWorld
I have a very limited quantity of some lug bolts that I think you will find to be very innovative. There was a lot of discussion going on about locks and I was saying that I may have something available soon that would solve a lot of peoples problems. I think I have it now!!!!
Let me introduce the Dency 2000 lug bolt to you. I had seen these in lug nuts but not bolts so now, we have them in bolts for the Mercedes.
This is everything that comes in the package-
Here are photos of the lug with the primary key-
Here is the bolt with the secondary safety cap installed-
Here is a photo of the bolt, secondary safety cap and the secondary key-
Let me take a second to explain how it works. The bolt screws in to hold the wheel iin place obviously, you need to use the special key to screw the bolt in just like any lock (that is where the function of most locks end). After the bolt has been screwed into place you push the silver cap on, no need to screw it, just push it and it locks into place. Once the cap is on there it cannot be removed without the key no matter how hard you try. The cap has a magnetic lock and the secondary key releases the magnetic lock when pushed on the top of it. It's an awesome concept that will leave thieves scratching there heads.
Here is the cap and magnetic key-
There is no lock that is more unique than this that I have found. We are importing these but we only brought in a small initial run to check wheel clearances and the such and I have a limited number of these left.
They are $170.00 and will offer you total piece of mind.
Old Oct 20, 2010 | 05:41 PM
Sportstick's Avatar
Another round of ICE
Interesting....two questions, please.....
1) Are the key patterns unique? The spacing and thickness of the splines looks intentionally uneven.
2) How will you control the sale of magnetic keys? Would some trial and error allow someone to find other magnets which accomplish the same purpose?
Thanks!
Old Oct 20, 2010 | 05:46 PM
Staff@RPM's Avatar
Yes, they are unique and individually keyed. People are not going to have idea how to get that cap off your lug. Nobody has ever seen anything like this before.
Old Oct 20, 2010 | 07:11 PM
Stone2486's Avatar
2008 C300 4matic Sport
They look like they may deter some people from taking your rims... but any knowledgeable person could have those off in less then a min...
Old Oct 20, 2010 | 08:52 PM
xtole's Avatar
2008 E350
what are they made out of? be specific as these carry alot of load
Old Oct 20, 2010 | 08:55 PM
andy_meng1024's Avatar
2003 SL55, 2010 C63
Does it work with the HREs on my SL? PM me your payment method if it works.
Old Oct 21, 2010 | 09:36 AM
Staff@RPM's Avatar
They are made with scm435 hardened steel.
Old Oct 21, 2010 | 11:57 AM
AZN Optics's Avatar
SPONSOR/MBworld Guru
do you have these only for MBs or do you have these for BMWs as well? They look pretty good.
Old Oct 21, 2010 | 12:27 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
These things look awesome!
Old Oct 21, 2010 | 12:30 PM
Staff@RPM's Avatar
I have only one set left for the BMW. We also just got all the equipment to start doing all the Active Autowerke flash's for the BMW's in house now, not that it will help you out in California.
Old Oct 21, 2010 | 01:51 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
Your BMW set, is it the long bolt or short bolt version? Need a set for my 745.
Old Oct 21, 2010 | 03:02 PM
Staff@RPM's Avatar
I have the 35mm shank length in stock right now for the BMW but I think I have the rest of the 28mm shank length BMW ones coming in tomorrow.
