note on changing front brake pads
Old 05-08-2011, 02:28 AM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Originally Posted by delirium
What technique did you use to get the front caliper spring clip on so quickly?
Very simple use a set of vice grips.
Old 05-08-2011, 02:34 AM
tanktube67's Avatar
Originally Posted by Captain Slow
Stop with the "stealership" bs. It makes you look juvenile
That how the dealer is tag in the forum so just get used to.
Old 05-08-2011, 02:43 AM
tanktube67's Avatar
Originally Posted by IGB
And your inference that his employer gets to pick and choose how many labor hours they can charge is invalid. Rates, for certain basic repair jobs are pretty much standardized... That is what "Captain Slow" meant when he said "If the book says it takes 3-4 hrs labour". So the service adviser writing the repair order enters a repair code into his terminal, and up pops the number of hours they typically charge for that particular repair job.
Same holds true for body repair and paint....
The reason why repair jobs are usually cheaper at independent mechanic shops is two fold:
  1. They may opt to charge less for an hour of labor and/or they choose to deviate from that standardized # of hours for a particular repair job...
  2. They may opt to use a lower mark-up on the price of the repair parts.
Both of those elements add up to attractive repair charges that can lead to them to getting and retaining those customers who are not stuck with the "I can only trust the dealer" mentality.
You are on the right track, what it makes independent shop to charge cheaper is that they mostly use aftermarket parts and what you mention the labor hour is cheaper, on the other hand the stealer charge more per labor hour is that their techs are up to day on training and they have all the special diagnostic tools and equipment.
Old 05-08-2011, 09:01 AM
Stevedotmil's Avatar
W204 2010 C300 Sport/6M
The rear went much faster than the front did on my car. The rear also dusted a lot more with stock pads than the front did. Im guessing the rear pads are softer, also there is more rear brake bias.
I just washed my car for the first time yesterday and noticed that the rear rims were much more covered in brake dust than the fronts as well.
Old 05-08-2011, 07:24 PM
jlb0125's Avatar
2010 C350
I am looking for a DYI on how to remove the brake pads. I want to paint my calipers.
Old 05-09-2011, 10:43 PM
WICK's Avatar
C350
SO- no one has a DIY- front brake pad-- for c350-w204?? please- help.
Old 05-10-2011, 02:06 AM
  #32
delirium's Avatar
C350
The front is very similar to the rear. Remove the two bolts from the rear of the caliper and the spring clip that holds the outer pad on. Its very similar to the rear: https://mbworld.org/forums/c-class-w...placement.html
btw, nice pic!
Old 11-14-2011, 08:12 PM
  #33
redruby88's Avatar
C350 2008, panorama
For those having problems with the front caliper spring clip, here is how I manage to squeeze mine in.
Push the 2 ends of the clips in to the slot. This leaves the center part to be slotted into the hole. So, put a rag against the rotor and wedge a screwdriver in the center of the metal clip. With some strength, you should be able to pop the center of the clip into the hole in the caliper.
Quick Reply: note on changing front brake pads
