Scratch removal kits + Who has swapped thier hood emblem?
Old Nov 7, 2010 | 12:23 AM
Cycosis's Avatar
2008 C230
Angry Scratch removal kits + Who has swapped thier hood emblem?
So I've been looking for a scratch removal kit for my car. I've got a ton of scratches in the area that joins the roof to the trunk and the roof to the hood. My guess is either *****es with their stupid purses with the big buckles in parking lots or birds and their ****ing claws. The one I bought today says we have some type of ceramic paint job? My paint code is C040 (black) so I can only use the second part of the kit, not the sand paper and the first chemical.
Also, I went to swap my hood emblem today from the OEM plastic one to a sunken smaller emblem that sits in the indentation and there was a brutal scratched-in line around the perimeter of the emblem in the paint of my hood. No I did not twist the emblem when removing it and no I have never removed it before. this was factory inflicted.
Anyone had this problem? I know there isnt anything I can do about it I'm just wondering if I'm not alone... Kind of a **** off cause there is one spot which is really deep and I don't think a scratch removal kit will help it.
Old Nov 7, 2010 | 06:01 AM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
Do you run your car through an auto car wash? If so, those areas will receive the most pressure from the spinning brushes when forcing the brush up as it is coming up each end of the car. Otherwise????
I have had my emlem off and did not have any paint damage other than a bit of surface scratching from the grit that had worked its way under it. If it is scratched to the paint, I would clean and paint the scratch. You will likely need to drive around a few days to let the paint cure before you reinstall the emblem.
Old Nov 7, 2010 | 03:50 PM
Peabody's Avatar
I had my emblem off as well, and there was no hood damage, though I would think a decent polish job should your surface scratches out.
