Oil Leak
Best not drive with the oil level low . It could collect air & wreck the pump.
It's pretty hard to park too. Safety issue.
e: Watch the engine temp either way while you are driving it, and if it starts running north, pull over, turn off the engine, wait 15 minutes and check your fluids again. Be prepared to top it off again if necessary, so bring a gallon of water and a quart or two of oil with you if possible.
