W204's and offsets of wheels
Rating: Thread Rating: 14 votes, 4.64 average.
Old 04-15-2013, 05:02 PM
  #801
Senatorov's Avatar
MB C280 4 Matic
Old 04-15-2013, 07:46 PM
  #802
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
Vossen CV2
20x8.5 F
20x10 R
running on Nitto Invo
235/30/20 and 275/25/20
Old 04-16-2013, 01:32 PM
  #803
mangoango's Avatar
08 C350
Originally Posted by black 230
yes its a little crazy but i guess go big or go home lol
im running megan coilovers with ssr ms3 wheels
still need an alignment and need to pull my rear fenders out more
Sick wheels! What's the specs?
Old 04-16-2013, 03:17 PM
  #804
black 230's Avatar
2012 MB C250 SPORT
@mangoango
My fronts are 18x8.5 +35 SSR MS3 titan silver
My rears are 18x10 +22 SSR MS3 titan silver
Old 04-16-2013, 03:18 PM
  #805
black 230's Avatar
2012 MB C250 SPORT
Nice and wet
Old 04-16-2013, 03:21 PM
  #806
black 230's Avatar
2012 MB C250 SPORT
Dat ***
Old 04-18-2013, 04:44 PM
  #807
940*'s Avatar
I WALK...
Will this set up work on the C63?
Front: 19x8.5 ET 38 5x112 LM 322
Rear: 19x9.5 ET 38 5x112 LM 323
What tires will I be able to run and what will it look like?
Sorry newb on offsets here.
Old 04-19-2013, 01:31 AM
  #808
mmike's Avatar
'10 C300
hopefully someone can chime in... looking into a set of wheels with these specs
19x8.5 et41 front and 19x9.5 et49 rear
tire: 235 up front 265 in the back.
im on stock suspension. should i have any problems with these?
Old 04-19-2013, 04:45 PM
  #809
Arjy's Avatar
2023 911 T, 2012 C63 AMG Coupe, 1989 560SL
new shoes went on today
2008 c300 4matic sport
OZ superturiso LM 19/8.5 all around ET44
stock suspension, live in mass roads are ****
Old 04-23-2013, 10:30 PM
  #810
Matt_Eurojerks's Avatar
w204 C300
Looking good Arjy!!
Old 04-23-2013, 10:31 PM
  #811
w204 C300
The rears will rub in certain situations.
Old 04-25-2013, 10:53 PM
  #812
baez350's Avatar
2008 c350
what do you guys think about this setup?
18x9 35 offset
18x10 45 offset
lowered on H&R coils
will this work? i wouldnt want any rubbing issues and i want the offset to fit nice with no camber
Old 04-27-2013, 04:02 AM
  #813
Leo977's Avatar
C class W204 2012
my details:
wheels 3sdm 0.01 concave
Front: 19x8.5 ET42 with Falken 452 225/35
Rear: 19x9.5 ET40 with Falken 452 235/35
Old 04-28-2013, 09:54 PM
  #814
maxx112's Avatar
c300 08
Help!
hey
just ordered some wheels 19"x9.5 +42 F and 19x10.5 +52 R haven't seen alot of w204 users with this spec,trying to find out what tires should i use for no rub and what mods would i need to run the wheels on my c300. can some help me out!.....
Old 04-28-2013, 10:12 PM
  #815
Cleanbenz's Avatar
2010 E350
Originally Posted by maxx112
hey
No one is running these specs because they won't work. Your front wheel is going to rub your struts. A +35 offset on a 9.5 left 4mm between my wheel lip and the strut. I think you will need to space them out to work. You'll also need to run a 215/35 to get enough stretch to keep them from rubbing and they still might rub.
Old 04-28-2013, 10:15 PM
  #816
Cleanbenz's Avatar
2010 E350
18x9 35 offset
18x10 45 offset
You will run front and rear. Might work with 215/40 and 225/40 tires. That'll look sweet actually.
Old 04-28-2013, 10:43 PM
  #817
maxx112's Avatar
c300 08
what about the rear??? what tire size do you recommend and would it rub?
Old 04-29-2013, 12:08 PM
  #818
Cleanbenz's Avatar
2010 E350
Those are the sizes I recommend, 215/40 front and 225/50 rear. If you go any bigger on the tire sizes you will surely rub. That's a lot of stretch to run so if you aren't comfortable with it you may want to reconsider the wheel sizes. Rolling and pulling fender might also keep them from rubbing. I'd like to see this setup work for you because it's sick but I fear your have rubbing no matter what you do. Most guys getting that aggressive rub at least a little though.
Btw, if you are on coils you already are running negative camber because it can't be adjusted without aftermarket camber bolts. If you are all the way down on the coils you will be at around -2 degrees which is what I'm at. That will definitely help you clear in the rear. If you correct the camber you'll most certainly rub badly.
Old 04-29-2013, 01:34 PM
  #819
maxx112's Avatar
c300 08
thank you for the recommendation you've been a big help i have c63 full suspension with h&r super sports springs on my c300 but want to get some coilovers for a lower drop but not right now,if i find some used ones with a good price ill take them loll.as soon as i get the wheels installed ill post some pics and let you know what i had to do to get them running good.
thanks Cleanbenz
Old 04-29-2013, 06:32 PM
  #820
baez350's Avatar
2008 c350
i just saw what loonie has and he's running 18X9 +38 215/40 Federal SS595
18x10 +38 245/35 Yoko S. Drives
also i changed my mine and I'm getting air
Old 05-05-2013, 10:06 AM
  #821
bringtherain's Avatar
01' c320 (sold) / 03' Ford Focus(sold) :( / 98' C230 / 00' SL500 / 11' C300 Sport RWD w204
Which version megans are you running? Reason I'm asking is because I'm running megans too and the rears aren't nearly as low bottomed out although I'm still on stock 17's atm.
Btw anyone try running 19x8.5/9.5 staggered ET35? Running the math there should be a little past fender if not flush.
Old 05-05-2013, 11:36 AM
  #822
DonjuanOriginal's Avatar
2008 C300 6speed, 2015 GLK 250 2017 E400 wagon
et 35 don't bother lowering it than. unless you stretch the rear tire big time. 19" and 35 et don't mix. et 45 and higher for the rear IMO. can use better size tire.
Posted from Mbworld.org App for Android
Old 05-05-2013, 10:47 PM
  #823
planning to run 225 in the rear. even if i ran et 45 i would be running stretched so yeah. just wondering if i'm gonna need to get camber arms.
Old 05-06-2013, 10:53 AM
  #824
This is a Lamp's Avatar
2010' C250 W204
Any recommendations for a set of 18"s rims?
5 spokes designs most preferred (and not the AMG rims thanks)
Old 05-16-2013, 06:31 PM
  #825
christian_monsi's Avatar
2013 c250 coupe sports amg package
Talking My Setup
18" Mach 7 2crave rims staggered 35 offset
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
Quick Reply: W204's and offsets of wheels
