W204's and offsets of wheels
#1301
help please.
I have a guy selling me a set of 19inch Forgstars off of his 2008 C63 for a damn good price and I'm curious..how will 19x9 +40 front 19x10 +45 rear with 235/35/19 front and 255/35/19 rear.. look on my*2012*C250*sedan.... I'm new to this whole wheel off set etc...so would this fit well or what sizes should I be looking for??? Or would this even work on my ride?? Looking for a semi aggressive look but want to be able to drop it a good amount without a scrubbing
Read more:*https://mbworld.org/forums/c-class-w...#ixzz3TQuRZwFU
#1302
Anything can be "made" to fit honestly. But are you willing to roll/shave fenders, run a semi stretch tire, or increase negative camber to fit properly?
Because I think the only thing worse than extreme hellaflush is mexiflush when the wheel AND tire poke outside the fender haha.
From what I've been reading that could be made to fit ok. Use the pics and specs from the members here and input into the offset calculator on 1010tires.com to determine the deviations.
#1304
You may need to have someone post up an alignment chart to figure out what the static camber looks like with that much of a drop. Increasing the negative camber may be required. Again though, I would use 1010tires to see the amount of "poke" vs some of the other setups that have been posted.
#1305
As FFM said. You'll be poking with those offsets. I'm running ET40 on a 8.5" in the front and I'm flush. Same with the back you want to be around ET55 to avoid them poking on a 10" wide. The C63 got wider fenders so they get away with it.
#1306
I really appreciate all the help from you guys..even tho it hurts the heart lol...I was so ready for a set..guess I'm not ready and will be waiting a lot longer to get a nice setup..
#1307
My advice would be take your time and do it right. Nothing worse than realizing you could have done "______" and then chuck spacers in haha.
I'm looking at the Vorsteiner wheels myself. Looks like they actually did their research and offer proper offsets for our cars.
Pains me to purchase a wheel over +40mm offset :cry:
I like that functional but aesthetically pleasing zone of 25-40 offset zone with the proper wheel widths.
#1308
This is another useful site.
www.willtheyfit.com
#1309
1 Post
2013 C250 Sport
Perfect flush non poking and safe to lower on super sports on 19" rims are the following setup.
F 19 x 8.5" wide ET35 225/35/19
R 19 x 9.5" wide ET40 255/30/19
Skinny series tires like Accelera Phi or any other brand is tire that is considered narrow type.
As for 10" wide rear rim lowest offset to run without poking is ET50 but will also need a skinny tire.
#1312
Newbie here..
I have a 2012 c250 and I just put on my new rims.. stance sc5.. 19s 45et front, 48et rear.. 235 35 19 f, 265 30 19 r..
Im planning to lower it using h&r super sport springs.. will I have any rubbing issue? I also want to put 5mm spacers on the back
#1313
Newbie here..
Any reason you want to run a spacer? I would avoid running a spacer and just get the wheels in the correct offset.
#1314
yes 19x8.5 front and 19x9.5 rear.
so I'm clear to take off? i won't have any rubbing issue with my offset and size of tires and rims?
and for spacers... my friend gave me a pair and i just want to see how it will look lol
#1315
Yeah you should be fine. If you look at the bottom of page 52 you'll see how it looks with 19x8.5 ET40 & 19x9.5 ET42 on mine. Running the same size tires as you are looking at. Yours are higher offset so they will sit further in.
#1316
I want the rear to look just like yours but my offset is higher than yours so should I use the spacers? Or ill have rubbing issue if I put it on..?
#1317
Well if yours are ET48 and you throw on 5mm spacers, then you'll end up with ET43 which is almost identical to mine. You might have to get some camber adjustment done to avoid occasional rubs. I have to do it to mine.
#1318
Newbie here..
![W204's and offsets of wheels-screenshot_2015-03-11-09-45-31_zpsrgqigse0.png](https://mbworld.org/forums/attachments/c-class-w204/375655d1542320766t-w204-s-offsets-wheels-screenshot_2015-03-11-09-45-31_zpsrgqigse0.png)
![W204's and offsets of wheels-20150224_174422_zpsn9mdrodr.jpg](https://mbworld.org/forums/attachments/c-class-w204/375656d1542320766t-w204-s-offsets-wheels-20150224_174422_zpsn9mdrodr.jpg)
#1319
thanks for helping.. appreciate it a lot.
#1320
#1321
Stock. But when the car was full load the rear was tucking a little over the tire and did not rub during my 2 hour drive. From the way it looks now, it looks like it will rub but when the car lowers it cambers slightly.
#1322
thanks
#1323
I would do a search on SS spring as some have reported no significant drop and you just screw up your stock shocks.
#1324
19s with h&r ss is just really nice to me.. lol.. its not a big drop but I can def tell the difference..
#1325
I don't think it's possible to not get a decent drop out of the SS. Just put them on my Sport 4matic and stock rear pads and still got roughly an inch drop out of it.
Yup, just confirmed with a tape measure to the pics I took prior to the install. Dropped around .750" the day off and settled another .250"+ since which was 5 days ago.
So looks like 1.2 front and 1.1 rear roughly.
