W204's and offsets of wheels
Rating: Thread Rating: 14 votes, 4.64 average.
Old Apr 14, 2016 | 10:19 PM
  #1601
JekJek's Avatar
2011 C350 4matic
Originally Posted by FAneek
With 19" 8.5 & 10 - i would suggest going with 235 and 255 or maybe 265 if you plan to use H&R SS. But if you're staying with stock ride height then i guess its fine with 245 & 275
As far as the stock lugs nuts it all depends on the wheels really.
A shop offered me a good deal for Toyo Proxes 4, but the size is 245 35 19 front and 265 30 19 rear. Any thought on this set of tires? Again, I don't plan in lowering my car. Unfortunately they don't have 235 for the front that would match the 265. If I use the 245 on 19x8.5 40 offset the rubber will sit flush, but the 265 on 19x10 with 52 offset would somewhat a little bit stretched? Does it look weird?
Any feedback is much appreciated.
Old Apr 18, 2016 | 06:41 AM
  #1602
Diese's Avatar
c300 4-Matic -12
Hey guys! Just ordered 18/8.5" ET44 -front ,18/9.5" ET46 - rear for my c300 4matic wagon. And now im trying to buy tyres for those. Manual says that 225/40 ,255/35 for 4matics. I have BC-racing coilovers and i'am just wondering,will they fit at the rear? My last tyres on 17" was 225/45 245/40 when i bought my car. What should i get? Any thoughts?
Old Apr 23, 2016 | 08:49 AM
  #1603
Jppatter's Avatar
18’ E400 4Matic
I plan on lowering mine on H&R SS with 5mm spacers in the rear. Would I be good with:
19x8.5 44et 235/35/19 front
19x9.5 45et 265/30/19 rear
Old Apr 24, 2016 | 10:28 PM
  #1604
Becksan's Avatar
2018 E43
Don't use the 5mm spacer in the rear, you'll most likely be rubbing. I run ET42 and I rub with people in the back. Also you want to avoid using spacers unless it is to clear brakes.
Old Apr 24, 2016 | 10:59 PM
  #1605
Lowflyer's Avatar
2012 C250 Coupe, 2017 C43 AMG Coupe
Originally Posted by Lowflyer
Wheel specs: Front wheels are 19x8.5 et42 with 235/35r19. Rear wheels are 19x9.5 et48 with 265/30r19.
I'm only getting rubbing in the fronts. I've tried thinking of every little thing that could cause such drastic results considering members such as yourself have ran the same setup. Unfortunately I've ran out of ideas.
Just a quick update for the record, dropped down to a 225/35 r19 and rubbing issue solved. Only thing I can think of is running the SS paired with bilstein B8's gave a lower ride height then that of SS with stock struts.
Definetly wasnt a cheap lesson learned. With that said, anyone looking to buy some 235/35 r19 Sumitomo HTR Z III's, I have 2 at a great price, message me.
Old May 23, 2016 | 03:56 AM
  #1606
ap10046's Avatar
CLS500 M113
Guys, am looking at a set of silver TSW Mirabeau's in :
8.5X19 (ET 32) and 9.5X19 (ET 40)
OR
8X19 (ET45) and 9.5X19 (ET40)
Tires will be the ubiquitous sizes - Michelin or Continental 235/35-19 and 265/30-19
I cannot find the correct offsets for a W204 anywhere, nor any pictures with them on, for that matter..Car is stock suspensioned.
Would really appreciate any input...as I will NOT be able to return them, if they don't fit.
Old May 23, 2016 | 09:52 AM
  #1607
ap10046's Avatar
CLS500 M113
OR
Anyone, please?
Old May 23, 2016 | 12:40 PM
  #1608
ap10046's Avatar
CLS500 M113
Could I run a 35 profile tire on the rear and 40 on the front?
Anyone running this combination?
Old May 23, 2016 | 01:42 PM
  #1609
Soundstream's Avatar
C250 Avantgarde S204 Facelift
Anyone here with 255 30 19 on 8,5J 19 ???
Old May 23, 2016 | 02:09 PM
  #1610
Becksan's Avatar
2018 E43
Anyone, please?
None of the front options are ideal for the car if you need it to sit flush. The ET32 will poke and the ET45 being .5" more narrow will make them sit further in. 19x8 ET45 would need a spacer to sit flush. Rear will have a slight poke.
Old May 23, 2016 | 02:23 PM
  #1611
ap10046's Avatar
CLS500 M113
Thanks for the reply.
I don't want any poke..but would a 9.5 ET40 at the rear really poke?
There aren't too many pictures of 204's with ET40 at the back
Old May 23, 2016 | 04:14 PM
  #1612
Becksan's Avatar
2018 E43
I run 19x9.5" ET42 on 265/30/19 Hankook Evo2 on my wife's car. It is lowered on H&R SS though.
Not the best picture. But I'll see if I can find another when I get home.
It rubs loaded and on bigger bumps. But you won't have that problem at stock height.
Old May 23, 2016 | 10:27 PM
  #1613
ap10046's Avatar
CLS500 M113
Wow! That's ET42?
I'm getting a great deal on a set of Mirabeau's and that's why I ideally don't want to miss them. But can't have them poking for sure...
Old May 24, 2016 | 11:24 AM
  #1614
Becksan's Avatar
2018 E43
Wow! That's ET42?
Are you planning on keeping it stock height or lowering? Just you'll have less poke when lowered as the wheels is going to lean in. It depends on what your goal is with the look, I go for flush fitments, but it's all personal taste. You might want to look into wheels made with custom offsets to make sure you get what you want.
Old May 24, 2016 | 01:57 PM
  #1615
ap10046's Avatar
CLS500 M113
Hi
The thing is I am getting this deal on only the Mirabeau's, Nurburgring's or a set of WSP C63 Reps.
It will be on stock height, preferably with 235/35 and 265/35
Old May 24, 2016 | 03:58 PM
  #1616
edgalang's Avatar
Factory ordered 2012 MB C350 w/Dynamic Handling Package
I believe he still will.
I've tried 265/35R18 on 18x9.5 +45 and it still rubbed on stock suspension using Michelin Pilot Super Sports.
I didn't think I rubbed in the beginning, but once you start going high speed you'll notice a rub here and there. I went back to 255 and the rubbing went away completely, but then again it all depends on the tire of choice, since PSS tends to run wide shoulders.
Old May 24, 2016 | 10:00 PM
  #1617
ap10046's Avatar
CLS500 M113
If there's any doubt, I would rather forfeit the Mirabeau's. As I said, they are non-returnable and I just cannot risk them rubbing. Shame.
If I went with the Nurburgrings in 19" (I'm currently using them in 17"), They do have offsets in the 45-53 range, could I then run a 265/35 in the rears?
Tires will mostly be Michelin PS2's.
Old May 25, 2016 | 09:07 AM
  #1618
Becksan's Avatar
2018 E43
Is it 19x8.5" & 19x10" setup or? You should be safe running ET40 front and ET45 rear. At least if you use Hankook Evo2. As Ed mentioned I don't know if the wall on the PS2 are wider.
Old May 29, 2016 | 05:33 PM
  #1619
Bosnie87's Avatar
Mercedes C 220 CDI w204
Will these be ok
18" 8,5" ET 48
245/40 front and back
Old Jun 3, 2016 | 01:46 AM
  #1620
a1rh3adsz's Avatar
'06 mz3, '12 R6, '09 W204, '02 A4 B6, '14 IS350
will it be okay to run square setup instead of the stagger setup for the 4matic?
i have a set of wheels mounted on tires already in the garage.
wanted to know if these will work/fit.??
18x9 +35 215/40/18 all around. ??? car is stock height
Old Jun 10, 2016 | 09:04 AM
  #1621
Hey Folks,
below my C250 Avantgarde
I would like to mount on the front 8x19 ET45 with 225 35 19 and on the rear 9x19 ET45 with 255 30 19.
Planned is also to install a Bilstein B16 suspension
Now I am little affraid if it will rub on the rear axle...
The stock AMG dimension on the rear axle is 9x19 ET54, 9mm less than mine...
Any idea if 9x19 ET45 will work without rub while max. load in the trunk?
Any pictures here how it looks like with 9x19 ET45 on the rear? To check more than 60 pages not funny^^
Many thanks and BR from Austria!
Old Jun 10, 2016 | 10:49 AM
  #1622
jay rick's Avatar
C63 2009
I ran with the same offset but wider by 0.5 inch front and back with 18. Also with bilstein 16 with one finger gap, no issues at all.
19 should hv pretty close diameter so you should be fine
Old Jun 10, 2016 | 11:09 AM
  #1623
Lowflyer's Avatar
You should be golden with those numbers. I'm running 19x8.5 rim with 225/35 tires front and 19x9.5 rim with 265/30 tires rear. Lowered on H&R SS with Bilstein B8's, no rubbing at all.
Old Jun 20, 2016 | 08:17 AM
  #1624
popcorn_skollie's Avatar
2012 Mercedes Benz C180
New here. So Hello...
I have a 2012 C180 Avantgarde.
I recently bought a used set of staggered 19s.
The deal was too good to pass up on.
Naturally I've been shopping for tyres
(and learning about all sorts of things)
It would seem that for my rims.
19x8.5 ET42 (front)
19x9.5 ET45 (rear)
The ideal tyre situation would be
235/35R19 for the front and
265/30R19 for the rear.
Now the front tyres aren't a problem.
They're a dime a dozen everywhere.
But the rear are more pricy in that size.
I can however get two
275/30R19 for almost half the price of the 265's
Just worried about rubbing?
I'm on stock suspension.
Old Jun 20, 2016 | 02:51 PM
  #1625
gmannap's Avatar
Mercedes Benz C250 2013
Hi, everyone.
I've been reading through this thread and noticed different setups for the W204.
I installed a set with the following specs for a 2013 C250 Sport:
19x8.0 ET45 235/35/19
19x9.0 ET45 265/30/19
The problem is that the tire rubs with the fender when entering driveways or some dips in the highway (only one in the car). I've seen 275 rear tires with no problem.
Any suggestions? Thanks
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
