Transmission Service
I just hit 60,000 miles and need to go in for some alignment work. I never had the transmisson service done. I thought perhaps I'd do it, but I don't even know what it is!
What exactly does the transmission service include and is it really necessary?
Kind regards,
Rick
Hope this helps.
Here:
https://mbworld.org/forums/c-class-w...ce-thread.html
You guys are right to think that the tranny is expensive. I have heard it is upwards of 12,000 to get a new one installed at the dealer in a friends 2007 e-class (and I don't imagine our 7G tronic to be any different).
RP
RP
RP
Least likely scenario is that you simply have a bad tire...
RP
Here:
RP
If your car has the 3 way fluted castor bolts fitted in the castor/thrust arm bushes, One is likely installed in the wrong position. Check your castor specs.
The dealer keeps wanting to do an alignment on my cars due to the way the tires wear.
I am always hesitant thinking they're wanting some money and because they drive *perfect* down the road, straight. Sure, on crowned roads they pull to right, but they really drive perfectly straight on a flat road.
Do I run any risk of the car not driving perfect like this, if I go ahead and let them do an alignment the next time?
On the 722.6 5 speed transmission the TC drain was deleted in 1999. It reappeared on the 722.9 7 speed about a year into production. I have never seen a W204 without a TC drain plug. Most W203's with the 722.9 had TC drains. 722.9 was fitted to other models prior to the C Class. Some of them have no TC drains.
Castor & camber bushes on these cars have a 3 position centre for alignment. They come with standard bolts that only allow use of the centre position. You require to buy fluted bolts to allow full adjustment (yes they are being cheap by not fitting them standard)
Benz SA have drummed into all dealers & alignment shops that for no pulling or irregular tyre wear you must set the castor 1 degree more positive on the passenger (then we cover LHD & RHD vehicles) side of the car than the drivers side - typically around 10.6 & 9.6. deg. - With this setting the car still tracks straight on a level road but will not pull with the typical camber of the road.
So have the fluted bolts installed. Have a proper alignment done by a competent shop. Ensure that the rear toe is correct as well - this is important for rear wear. I posted the method here.
https://mbworld.org/forums/c-class-w...ing-tires.html
The pics I've posted are from a W203 but the parts are interchangeable
