Do you scrape quiet a bit? Can you make it over speed bumps/into driveway? Im curious because my wife will be driving the car but I dont want to worry about the car bottoming out on speed bumps and scraping the paint off the front bumper and im not sure if just the regular sport springs will make it look nice! Any advice is greatly appreciated! Thanks!
I assume you can make it over speed bumps no prob. I never had a problem with speed bumps but steep driveways were a problem for me in my last car. Angled entries in/out of driveways are key to keep the front bumper from getting scraped. ( I am sure you know that already)
Quote:
nah i think u will be aight with supersports even when i had one coil cut off of em still cleared the speed bumps, just watch out for them parking curbs...Originally Posted by xXHotelCrazyXx
usually most people i kno who got the sport springs regret it.... the drop still leaves a sick gap between the wheels and fender...
Awesome, thanks fellas!
Super Sports
Make sure you get the 5 mm rear pads to make the drop more even with the front
I have super sports with a front lip... Just be careful when descending a steep slope and watch out for those 3 inch high parking curbs
Where do i order the pads? Thanks for the help!Originally Posted by ZeroSeVen
Super SportsMake sure you get the 5 mm rear pads to make the drop more even with the front
Quote:
from the dealer, they are like 10 bucks.Originally Posted by xXHotelCrazyXx
ExploreDo you have a pic of what these look like? So i would just tell the dealer i want 5mm rear spring pads? Also, does 5mm really make a difference?
i can take a pic of them in a few hours when i get home, i'm at work right now.
They are just black rubber circles with holes in them.
Quote:
Stock is 13mm. So yes you are getting an extra 8mm of low... Originally Posted by xXHotelCrazyXx
these pads are suppose to level the car, rather then the rear being raised slightly like stock.
this is what i have gathered from reading posts here.
Quote:
Ahh gotcha, thanks guysOriginally Posted by Matt@EuroJerks
Quote:
decrease in thickness... stock pads are 13 mm thick thus making the springs sit 8 mm higherOriginally Posted by blue00r6
is a 5mil pad an increase or decrease in thickness from what comes on a stock RWD?
Quote:
Im looking into installing 5MM pads in the front on my 2012 W204,Im running H&R SS and i hate how the front sits,can you send me a pick before and after to see if its a big different.My car sits lower in the back and it kills me looking at it,will it level out with the 5mm pads?Originally Posted by Blazeitup123
You may not have read this fresh one:Originally Posted by Blazeitup123
these pads are suppose to level the car, rather then the rear being raised slightly like stock.this is what i have gathered from reading posts here.
The problem using H&R SS springs on a 4MATIC
H&R does not make an engineered SS spring set for the 4MATIC.
Quote:
i dont think there is a different spring pad or even one in the front?Originally Posted by IW IE IS IT IA
Im looking into installing 5MM pads in the front on my 2012 W204,Im running H&R SS and i hate how the front sits,can you send me a pick before and after to see if its a big different.My car sits lower in the back and it kills me looking at it,will it level out with the 5mm pads?Thanks
i might be wrong but i dont recall seeing one like in the back.
my rear is nice with no finger gap but my fronts have at least a finger and a half
im just confuse about all these 5mm pad talk lol so when i purchase these pads from a local dealer do i order rear 5mm pads for the front? this finger gap been driving me crazy.
Thanks!
Thanks!
There's no pads that go in the front. They are only for the rear.
Quote:
Thanks!
The 5mm pads in the back is just to make the car straight, even if it creates a gap between the front and the back. By default, the back of the car is more raised from the ground than the front.Originally Posted by IW IE IS IT IA
im just confuse about all these 5mm pad talk lol so when i purchase these pads from a local dealer do i order rear 5mm pads for the front? this finger gap been driving me crazy.Thanks!
Quote:
So there's nothing I can do to the front other then purchase new springs or cut them your telling me?Originally Posted by itsLoonie
Quote:
Hate to say it but yes or get thicker pads to level it out with the front.Originally Posted by IW IE IS IT IA
no scrape, even with a front lip I am fine...
only problem is on certain driveways, where you must take an angle or you will be f*cked and scrape, so you gotta be careful and watchful of hazards way more than stock
