new pics of my C250CGI Brabus B25s with MY2011 LED Strips and modified light pattern
SubscribeLooks fantastic man...let me test drive it again next time I come back to HK? heheh...
Quote:
sure my buddy, when u will come to HK?
Quote:
yes..LOL Originally Posted by masterstudent
In the 2nd pic, did you ask your wife to wait in the car while you took the picture? Haha
since it was quite windy and a bit cold there, i just ask them to get into the car first...!
Quote:
actually they are the models i hired for the latest C brochure..LOLLOLOriginally Posted by joshg1001
^^ wife and parents. lol
Quote:
Any info?Originally Posted by Tekker
I'm also very interested in the LED lights for retrofitting and especially the control module?
can you pm the part no. for complete retro including the module..What is the degree of difficulty to install them..wiring?plug n play? thanks!
ExploreQuote:
not really plug and play, but not that difficult if you can find the right parts!Originally Posted by chasieboy
check PM
Quote:
check PM
I didnt get your PMOriginally Posted by sailexc250
not really plug and play, but not that difficult if you can find the right parts!check PM
I didnt get your PM
haha i left you over.. check pm!
Quote:
Can you respond to PM please or post how the install/module works for the DRL LED lights? Did you wire to your fuse box or to the wires? Originally Posted by sailexc250
Would a DIY be too much to ask? lol
Has anyone successfully retrofitted their pre-2011 w204 fogs to the new LED strips other than Sailexc250?
Seems really complex with a 'control module' to control the brightness.
Does anyone know if you can buy the parts and connect it without any control modules? Will it work without an error if I don't care about the brightness control?
This is what he wrote to me in a PM:
hi!
A2048852814
A2048852914
A2048850053
A2048850753
A2048852774
A2048852874
A2218201756
A2218201856
The above parts are all u need for the retrofit of the LED DRL, which includes all the neccessary mountings. Once you have done it u cannot revert back to original as u need to cut off the mounting points of the bumper behind the original fog lights
( don't worry about it, u cannot see the cutting from outside after the installation of the leds).
For the control module and the adapter, I have found out a Mercedes specialist from Japan who made very good quality retrofit led kit with wiring harness for various mercedes models, and fortunately, they can be able to communicate in simple English and most importantly they are willing to ship overseas.
Have a look at this website, I order the control module directly from them
http://www.prostuff-net.com/w204/w204.html
From the main page there is a button " inquiry in English" , use this to contact with them.
For the price of the control module with the necessary harness and the resister , they charge 40000 yen + 4000 yen shipping to Hong kong,which should be
equivalent to us$ 520 grand total. I reckon it is expensive, but their quality is very high hassle fee.
I don't have pics of the control module, I will take a pic of it later on. It is attached with the fuse box along with some wiring harness to make the retrofit work.
Hope this helps
Sailexc250
hi!
A2048852814
A2048852914
A2048850053
A2048850753
A2048852774
A2048852874
A2218201756
A2218201856
Hope this helps
Sailexc250
I would be interested in an install without the control module as well. If anybody has done it please let us know.
Quote:
Yes it is possible. But u need to find out
1. Suitable adapter ( since the plug is different for the LED strip, smaller)
2. Suitable resistor ( since voltage is different )
There is a fellow Hong Kong member (Coconut) Who have done this b4.
You can try to ask him!
yes, mine is using fog light switch on/off ..... the tuner installed some resistors plus some relay to avoid the the fault code which shown on dashboard . Originally Posted by sailexc250
Yes it is possible. But u need to find out 1. Suitable adapter ( since the plug is different for the LED strip, smaller)
i saw in japan yahoo bid also having somethings like this.... but not sure it's the right one or not !
hi,
I get all complete with ECU in http://omtuning.wordpress.com/oem-il...cion-original/
Hi guys,
just an update from a guy in the UK london.
MB main dealers will not confirm the parts you need until you give them a chasis or numberplate for a car that already had these (DRL) fitted from the factory.
I have noticed all late made AMG Sports C classes c250 and above (pre facelift) have these DRLS as standard and you should be able to get a number plate from the autotrader to give them.
There are 4 parts for each side and the parts numbers have been given by other members.
If you wire them directly to your fog light wires they will blink, so as suggested or as CKSperformance have advised is to wire them to the front SAM Control unit.
CKS will supply and fit these for you for about £600 roughly...
I had to go through the trouble to find out how to fit these because my car was repaired after a accident and I was given a bumper for DRL's. If you have a sports AMG bumper with round fogs, you need to cut the fog light housing out.
See the installation PDF on this page to see how! its under the installtion link.. above the add to cart writing!
http://www.cksperformance.com/index....ducts_id=21242
Hi sailexc250, i'm a w204 pre-facelift owner in HK. Will you mind PM me the garage that you use for changing the OEM LED DRL lights plus the Japanese controller? How much does it cost for the parts & labor? Thanks a lot!!!
Id be interested in hearing about this module too as Ive done the conversion but some how dont think we`re gonna get this information from this source!
