i need some help... :(
Old Feb 12, 2011 | 05:58 PM
cthumarshall's Avatar
C350
i hav an air leaking problem on one of my wheels.. but the weird thing is., it only happens when i hit the freeway and start cruising arnd 70mph... it doesn't leak on the city roads when i usually cruise arnd 50mph... i hav no idea why this is happening... any help would be appreciated... thanks...
Old Feb 12, 2011 | 06:13 PM
EASYDOES1T's Avatar
'08 c300 sport
Does your tire pressure sensor go on?
Old Feb 12, 2011 | 06:22 PM
C350
yes..
Old Feb 12, 2011 | 06:31 PM
efx1's Avatar
C350
You might have a puncture in the seal if you have a 3 piece wheel
might of happen during install
Old Feb 12, 2011 | 06:41 PM
C350
yes i hav 3pcs wheel... how can i fix it..?? thanks for the ans bro...
Old Feb 12, 2011 | 07:33 PM
wnunez89's Avatar
c350coupe, Gencoupe R-spec
i had the same issue on my old car (also had three piece wheels) i had to send the wheel in to get resealed
Old Feb 12, 2011 | 08:22 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
I was watching a tv show and they were installing a 3-piece wheel set. They were running a bead of silicone along the inner seem. Not sure if that's something a local shop can do.
Old Feb 12, 2011 | 09:38 PM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
you might need a new valve stem. It happened to me with my moms car so i replaced the whole stem and "Boom" it stopped the leak.
Old Feb 13, 2011 | 07:51 PM
LaicepsYdobon's Avatar
2011 E350 Sport 4Matic - P2 & Drivers Assist / 2010 C300 Sport 4Matic - P2 / 2013 Porsche Cayenne S
You might also want to have the dealer check your rims for hairline fractures.
Old Feb 13, 2011 | 08:25 PM
E350 Sport/ML350RWD
I had that problem too when I changed my rims. They didn't use the rebuild kit when they transfered the TPMS. I had them reinstall with the kit and everything was fine.
Just a suggestion.
