Valentine 1 - Hidden Install
Installed my Valentine 1 radar detector this weekend.
The V1 is located in the front bumper in an enclosure from Midcity Engineering. I'd take a picture, but you can't see it... The enclosure is white plastic, but I painted it flat black. I lose the laser detector with this install, but from what I understand its generally just a notification that your getting a ticket. Radar sensitivity seems good so far, but I'm open to moving it if it doesn't seem effective in the next few weeks. Wiring is run through the fuse box and into the dash.
I also installed the Midcity Engineering V1 interface which displays the V1 messages in the middle of the guages. This install was very easy. It just plugs in beneath the driver side door sill.
Power, volume, mute, etc are controlled with a Valentine 1 remote audio adapter, which I took out of the box and installed in the center console. I sat in the car for a long time figuring out where to install it. Besides the ashtray, there is not a lot of room. With some help from a dremel, it just barely fits into the gear shift panel. I did a lot of test fits to get it to fit properly. Luckily the hole lines up perfectly in the gear shift panel. Power is from the cigarette lighter.
Very nice. I reviewed this product on the MidCity website and I don't see pursuing it myself. You lose rearward radar detection which is one of the primary benefits of the V1 (I believe it's the only one piece radar detector with rearward detection). I had an older one years ago and it served me well. Looking to get a newer one shortly.
The fact that its hidden and hard wired means I don't have to put it away to prevent someone from stealing it. It also means I don't have to put it back up - in which case I'd probably be lazy and after a while I'd probably stop using it. This way, its always there and I don't have to think about it.
I could possibly move the unit to the back center headrest or maybe the front of the headliner. Anyone put one in the headliner? I really don't want to see the unit at all.
I'm a major V1 fan, after having had Passport. Arrows and bogey counters are excellent, and sensitivity to falsing can be adjusted. The built-in installation is great, but too bad about laser. If you drive with the concept of having a "leader", you can effectively pick up the limited scatter of the laser gun when the leader gets "hit". I've used this technique successfully for years and the only laser ticket from waaaay back when happened when I was in front with no leader. The limitation is having to wait for some rabbit to come by who wants to drive at the speed you are hoping for and just trail about 1/4 mile behind. This is a highway technique...on city/residential streets, I am pretty strict about speed limits.
2012 C250 Coupe
Sportstick, I am surprised that you like Valentine V1 over the Passport. You had the one with GPS for false threat detection right?
How much of a problem is that with the V1, a lot of people complain about it.
Also, has anyone ever heard of the BEL 980. I saw it mentioned in a review where it did very well.
2012 C250 Coupe
It rates the 8500 #1, Bel 980 #2 and Valentine V1 #3.
However, it is a bit of an older review, the Bel 980 was replaced by the Bel 995. Can be found for around $200 new.
http://www.askmen.com/entertainment/...h_gadgets.html
1) If it works better to give location and number of radar sources to provide better protection so you don't get stopped, it doesn't matter.
2) If you get stopped with one of the others (and it is not fully built in), the officer will be watching for arm movement (they are thinking drugs/weapons), so you won't be able to get a BEL or Passport off the windshield/visor without being seen, so, again, it doesn't provide any advantage once the office walks up to your door.
If that is the basis of being third place, I think a different reviewer should be consulted.
Don't see one, but that would defeat the unique advantage of arrows and counter! I guess I don't see the value in running dark for the logic in my last post. Much better would be a full built-in with cluster read out that does not sacrifice the laser antennae.
http://www.valentine1.com/v1info/pdf...ns_pg14-16.pdf
Much better would be a full built-in, with cluster read out, that does not sacrifice (with only one "a") the laser antennae.
This would have made my intent more clear. Thank you.
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
I have my V1 mounted just to the right of the mirror (with hidden wiring, of course) and if I'm worried about the lights being seen by a following car, I can just tilt the visor down a bit.
Unbiased testing, not.
Just read that review and must admit to chuckling at the writer's logic. The V1 downfall to 4/5 is that it can be seen by police, to which I ask, "So?"
Except Valentine which is sold direct by the manufacturer.
Looks a little fishy to me.
Yes, I'm on my third V1 and it's saved my bacon more than once.
I just got a new radar, I got the escort redline which is sort of a direct competitor to the V1. I will say the range on the redline is HUGE.
I just didnt want to wait for the V1 to come in the mail. Plus the redline works awesome in Texas against the Ka state troopers for my highway driving. Radar already paid for itself with 4 saves in a round trip from Dallas to Austin. I dont speed on city streets so it isnt needed there, just open highways.
2011 C300 4Matic Sport
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
https://store.valentine1.com/Store/
Item 20110 Concealed Display with Band Identification
RHD C200 Sport Coupe, RHD SLK-55, LHD SLK-350
Got a 9500ci in the SLK, and it's paid for itself about 10 times over. Didn't like the options for remote install on the V1, and having a built-in / concealed unit was a "must have" for a convertible. Huge plus - for quality top down driving - is the "auto-mute" functionality that mutes the radio when the detector goes off.
Rob @ midcity was working on a CAN integration module, not sure if it's on the market.
