Will it Fit? Help me please
Old Mar 30, 2011 | 05:37 PM
dnksolo's Avatar
C55 AMG
Hello. I got 2008 w204 C300 4matic Sport mercedes. I want to buy Giovanna dalar Rims with specs : 5x112 19" 8J ET50 front and 19" 9J ET50 rear. Or maybe it would be better to buy all 8J? Help me please, im so noob at this question
The rims i want
P.S. Here are my stock rims
Old Mar 30, 2011 | 11:42 PM
SuperBeaverAMG's Avatar
S204 T-Modell C230 AMG Pack
They will fit you easily, with no problem at all, 8 - front, 9 - rear. You can do even wider.
Front - 8,5
Rear - 10
But then you should be looking to ET more carefully.
Old Mar 31, 2011 | 04:19 AM
dnksolo's Avatar
C55 AMG
Front - 8,5
Rear - 10
Thank you so much.
Stragged wheels and 4matic? No problems?
Old Mar 31, 2011 | 04:23 AM
tbal's Avatar
Haters crazy
The stock 17" amg rims that came on our c350 4matic had wider tires in the rear... I put staggered 20s on it and have not had any issues for about a year now... just finished lowering her too, all is good
Old Mar 31, 2011 | 05:15 AM
dnksolo's Avatar
C55 AMG
Old Mar 31, 2011 | 05:16 AM
dnksolo's Avatar
C55 AMG
And what tires i must to buy?
Old Mar 31, 2011 | 05:18 AM
Thank you so much.
Frankly speaking, I heard that it is better to set same width to 4 matic: rear, front.
In case you do different you can set as follows:
Front: 225/35 or 235/35
Rear: 255/30 or 265/30
I advise as I am doing my summer wheels now and they are:
Front: 8,5Jx19 with 235/35
Rear: 10Jx19 with 255/30 and 265 not acceptable, will rub.
Your are a bit more narrow - 9,5, so you can set 265 I suppose.
Old Mar 31, 2011 | 05:19 AM
tbal's Avatar
Haters crazy
totally depends on the setup... use search and go through the threads, many many people have ran 18-20" setups with diff tires/rims.. A LOT of factors, eg rim widths/sizes, offsets will determine what size tires you can run without rubbing issues.
For example on our c350 I have 20x10 rear, 42offset with 265/30 in the rear... Barely rubs, but not wrecking the sidewall so its good to go.
Old Mar 31, 2011 | 06:03 AM
burnteggroll's Avatar
w204 - 350 N other white cars
[quote=tbal; A LOT of factors, eg rim widths/sizes, offsets will determine what size tires you can run without rubbing issues.
+1
For example on our c350 I have 20x10 rear, 42offset with 265/30 in the rear... Barely rubs, but not wrecking the sidewall so its good to go.[/quote]
what is the offset for the front?
