Exhaust hp explanation
Also why would a more aggressive muffler system like eisenhaus Improve hp?
Sorry for the dummy questions. Thanks
The ideal system will generate sufficient pressure waves to limit fuel escape but not limit cylinder fill at high RPMs by using baffles to reflect the pressure waves so that as RPMs increase, more waves arrive after the exhaust port is already closed. By reducing the strength of these pressure waves, they increase flow volume, which increases horsepower.
Keep in mind that the weak link syndrome applies here. If you dramatically increase the "more air out" side w/o increasing the "more air in" side of the equation, you may not see the desired result.
My guess is that the exhaust on these cars is not the weak link and thus adding exhaust is really more for fun and not real results.
