Warning Valve Stems on 18 AMG Wheels - Photos
...about a year ago I lost one of the factory "grey/siver" valve stem covers and replaced all four of my valve stem covers with a set of genric chrome caps which looked nice until the other day when I was driving and the "tire pressure indicator" started to come on......I pulled over and did a quick visual check and the tires seemed fine....so I proceeded to the closest gas station and when I took off the chrome caps metal valve stem crumbled...luckily I have a good relationship with the dealers so they covered the replacements had they not it would have been a $200.00 repair.
Below are pictures of the driver and passenger side valve stems after the valve caps were removed......you'll note that the valves are in tact.....but the valve only had one and 1/2 turns securing it....had I been driving at speed and this had failed....you probably wouldn't be reading this on the forum!!!!!!
In short....take a minute...and check you valves stems....if you have a set of chrome caps throw them out and go back to the rubber ones as this was caused by a combination of road salt and unlike metals reacting.
Scott
Never had a problem in Colorado for a few years on one set of caps as they use magnesium chloride instead of salt.
I don't have the AMG wheels, they are aftermarket wheels with metal valve stems, so I guess this could happen to anyone.
There is a member who had the same problem but with the OEM plastic caps, but it may be due to either over tightening or impact to the stems:
https://mbworld.org/forums/c-class-w...g-scammed.html
Anyone know of any good sources of stainless steel caps instead of cheap chrome/aluminum ones?
