Alternative to OEM Jack
Obviously Im looking for something compact that fits in the car.
I keep a set of reflective triangles and cones in my car to lay out in the case I am working dangerously close to the roadway. Getting run over by another driver is a bigger concern of mine when changing a tire than the stock jack failing.
If you don't want to cough up the dough for jack stands, leave your rim (face up of course) under the body as close as possible to the stock jack point. In the case that your car DOES fall off the jack, you might damage some body panels but you WILL be able to get back under the car and lift it using the jack again.
In any case you will have to find a jack which fits the jacking point of your car.
In my opinion the OEM jack is OK for the odd time you have to change a tyre away from home.
I use small 2 tonne trolley jacks for the concrete floor at home with specially made steel blocks welded to them which fit the cars jacking points.
http://www.tractorsupply.com/jacks/b...r-jack-0116479
It is also a lot heavier to cart around wasting fuel over the life of the car.
