Rear-ended! What now?
Other info: my head rests "broke" forward
Everyone seems to be okay at the moment, I have some neck pain. Let's see how that goes.
Haven't spoken to body shop yet ... how much is this going to cost him? Chances of frame damage?
Try to give it to me straight without scaring me one way or the other, please. Thanks!
For damages your looking at $2000 around if they replace that bumper... Take it to a certified collision benz dealer, so it doesn't void your electronics warranty if some electronics are damaged..
Also the head rests for driver and passengers are considered airbags.. I didn't notice when mine deployed when I was rear ended till the SA pointed it out.
Got his name, insurance, etc. There were witnesses to his admission of fault. In D.C. police don't make a report unless someone is hurt. I'm not worried about him admitting/not admitting at this point - I have pictures and witnesses.
I'm going to take it to the dealership's body shop which is DEFINITELY a certified Benz shop ... you think there's going to be frame damage? Do the head rests need to be replaced?
Thanks!
They "break" open in that they separate and you can see the insides.
First initial estimate was about $2,000 I think. After they took off the bumper and what not, they estimate another $3000 putting it to a total of $5,000. Good thing is there was NO frame damage. Hopefully that helps.
I'll let you all know what happens.
Thank you very much for your concern about my neck pain - I've been in a worse accident and recovered well and I appreciate your kind wishes.
And keep the rental car until then.
Be sure not to sign anything without reading and understanding every word first because you don't want to release the other insurance company until your possible medical claim is completely resolved.
I'll disagree with the $2000 estimates, simply because replacing and painting the bumper cover by itself, should be less that $2000. However, assuming the impact happened at a speed closer to 15mph than at 5mph, I suspect the absorbers, as well as the the impact bar (and associated hardware) will also have to be replaced. Add in mechanical labor hours/paint labor hours and it'll probably put it at closer to $3000, (maybe more if the headrests must be replaced).
But really, what difference will it make how much? I'd be more concerned with paint/color match, OEM parts, and the insurers can duke it out on all other issues.
And even more important than all of the above, is that you and your passengers are all alright... Hope the soreness and pain will dissipate soon.
Thanks for all of your help! His insurance paid the claim and my dealership's body shop charged $2,057 for the bumper cover, plastic piece below the bumper, impact bar and alloy tailpipe to be fixed with OEM parts. There was no serious damage or frame damage. The headrests popped right back into place.
Best,
Sammy
Best,
Sammy
Also, just for normal evasive maneuvers on the street, the optimal leverage occurs at a position with arms slightly bent. The rule of thumb has been to stick your arms straight out to the windshield, adjust the seat until your wrist is over the rim, and then bend your arms slightly to back off and grab the rim. That should also provide a comfortable leg position, unless one has an unusual leg/arm length proportion. I am 6'2", and find this works very well in the C.
All vehicles have frames. All. The frame serves as the attachment points
for the front, side, and rear inner structures of the car. An example of a rear inner structure is a rear floor pan. Inner structures are thus named
as they cannot be seen b/c there is outer sheet metal, usually . You *can* see a rear floor pan; take up your trunk cover, or slide underneath the rear bumper of your car. See the un-clear coated sheet metal?
That's your floor pan. Your spare tire usually sits in it. BTW, see the
pole looking thingys that the rear bumper reinforcement is attached to? That's your rear frame horns. FRAME!!! After the inner structure is attached to the frame of the car, the uniside and other sheet metal is attached (if it is a uniside vehicle).
A uniside is exactly that: one piece of outer sheet metal that encompasses
the rear quarter panel, rockers, door openings, and rails. It is ONE piece, hence uniside.
BOF designs for cars were given up by most companies decades ago as being too heavy for optimal fuel economy and performance. Trucks continue to use BOF due to requirements for towing and hauling, with their high-capacity hitches attaching to the frame and not the body.
This may be a language issue, as there is no design or area of a vehicle called "uniside" ....you may mean "unitized", or some have called that design "unibody", but it is in distinction to body-on-frame. Your definition of "uniside" seems to be closest to what is called the "aperture", which is welded to inners and outers, floor pan, rear valence,and roof panels. The dash (not the instrument panel, the real dash, also called the firewall) and cowl and engine box with shotguns (not actual guns...things which look like tops of frames actually to absorb crush) are also welded assemblies. Front fenders are typically bolted on.
You can trust me on this after 25 years working in the auto industry for one of the big 3, and spending waaaay too many hours in the plants.
This may be a language issue, as there is no design or area of a vehicle called "uniside" ....you may mean "unitized", or some have called that design "unibody", but it is in distinction to body-on-frame. You can trust me on this after 25 years working in the auto industry for one of the big 3, and spending waaaay too many hours in the plants.
