Installing RearView Camera on 2012 C Class
Old 04-03-2014, 03:38 PM
  #76
chrisdean's Avatar
W205 C200 AMG Line Premium
Strip the camera down to just the basic cube and cut the cable about 30cm from the camera. Drill a small hole that the camera cable will fit through inside the top corner of the trunk handle. Feed the camera cable through the hole from the outside, reconnect the cable (when you strip the insulation off there's only three wires to connect) and you're almost done. Use some 3M double sided tape or your imagination and you should be able to secure the camera at the correct angle inside the trunk handle on one side. Result central location for camera and twin led's retained.
Old 04-03-2014, 03:57 PM
  #77
shotgun_banjo's Avatar
'13 GLK350 4matic,'09 C300 4matic,'15 GLA250,'07 Honda Odyssey, '18 GLE 43
Why go all the trouble in gluing things down and just get this one instead:
http://www.ebay.com/itm/Mercedes-Benz-C-class-W204-Handle-Reverse-Camera-Car-Parking-Backup-Rear-View-/251031182826?pt=Car_Audio_Video&hash=item3a729fddea&vxp=mtr
This was my first choice but I told myself I will try the $19 camera first and if that didn't work I will go with this. In the end I loved the el-cheapo cam.
Old 04-03-2014, 04:12 PM
  #78
TheRulesLawyer's Avatar
C350
Mercedes Benz C Class W204 Handle Reverse Camera Car Parking Backup Rear View | eBay
That appears to be the $19 camera mounted on a custom handle bracket. I wonder if it would affect keyless-go for the trunk? I saw that before I ordered, but in the end I decided I didn't want the camera blocking the trunk handle.
Old 04-03-2014, 04:18 PM
  #79
chrisdean's Avatar
Because if you've been on ebay and bought a camera that is supposed to fit on a 2012 and it does'nt what else are you going to do with it? Of course with 20/20 hindsight I'd have bought the right one but there's satisfaction to be had with some improvisation and 've given someone a cost free solution for their problem.
Old 04-03-2014, 11:56 PM
  #80
jjcrews01's Avatar
2012 C250 Sport Sedan
Originally Posted by TheRulesLawyer
I ordered a different camera
http://www.ebay.com/itm/121150021490...84.m1497.l2649
It metal and a sony CCD. 520 TVL.
I haven't installed yet, but i Plan on drilling a hole in the mounting plate used for the factory camera and mounting there. It'll allow both LED backup lights to remain. Hopefully I have time to put it in this weekend.
I think I'm gonna go with the original choice of camera and get the fakra cable.
At least I know it has already been done and works.
Old 04-04-2014, 01:10 AM
  #81
C350
FWIW
http://www.otofun.net/threads/272316...-2012-cua-em-d
Looks like the same camera I got (This is from vietnam). I know someone else used the same camera in France.
https://mbworld.org/forums/5896226-post281.html
and
https://mbworld.org/forums/5934927-post287.html
It doesn't really seem to critical other than you want one that is NTSC for the US. For my2012+ the light replacement ones don't work so hot so might as well consider the other options.
Old 04-05-2014, 02:13 PM
  #82
tofu-'s Avatar
c63, 335i
hey guys... just wondering, but why doesn't anyone just use 3m double sided tape instead of going through the somewhat difficult mounting process with drilling and brackets? these cameras are extremely light, so they won't go anywhere with that tape.
i personally prefer the handle camera, but i'm not sure if it fits my 2009. are the trunks the same?
Old 04-05-2014, 02:48 PM
  #83
jjcrews01's Avatar
Idk if the trunks are the same but I think u can't just use double sided tape because the camera has to stick thru the trunk a little bit to be flushed.
It seems it already sticks out as is.
Old 04-05-2014, 06:04 PM
  #84
tofu-'s Avatar
c63, 335i
you're right. I jumped the gun a bit
I did not realize i'd be drilling through a replaceable plastic piece. I thought you guys were drilling through trunk metal!
I use an ebay trunk handle camera on my e92 and it was a cinch to install, so i'm hoping i can do the same with the w204. the great part is that it's only an inch or two off center.
Old 04-06-2014, 12:20 PM
  #85
tofu-'s Avatar
c63, 335i
well, i ended up buying the boot handle camera for my '09. we'll see what happens.
Old 04-06-2014, 03:22 PM
  #86
C350
You have to make holes for wires and disassemble for the wire routing anyways. Might as well mount it securely even if you could get away with tape.
Old 05-18-2014, 02:42 PM
  #87
jjcrews01's Avatar
I finally installed my backup camera and unfortunately I only have the left side LED license plate working (with the right side LED removed bcuz of the camera). Another issue is, sometimes I get a unclear-scrolling screen on my display when the engine is ON and I'm in reverse. When the engine is off and I put it in reverse the display of the backup camera looks fine.
I checked all connections and I made sure the RCA connections are insulated from touching any bare metal. I grounded the black wire to the existing ground screws in the passenger side trunk and I used the passenger side tail light connector to hook up the power to the reverse light. I also went into the engineering menu and added the reverse camera. Does anybody know why this might be?
Old 05-18-2014, 03:36 PM
  #88
chrisdean's Avatar
You didn't need to go anywhere near the lights to get power, all you need to do is us an "add a fuse" and connect to fuse 71 in the rear fuse box. It is, if you like, a purer source of power for the camera.
Old 05-18-2014, 09:54 PM
  #89
jjcrews01's Avatar
It works now. Thanks for the help chrisdean. Didn't know the camera was so sensitive.
Old 06-03-2014, 06:16 AM
  #90
ICON 1's Avatar
2013 C300 Sport
Cool
What size fuses did you use for the "add a fuse"? Slot 71 is a 15 and that would go into slot 1 in the "add a fuse" but what about slot 2?
Old 06-03-2014, 06:44 AM
  #91
lemonstand's Avatar
2014 C63 507 Edition Sedan - Mars Red
Slot 1 is the powers the ciggetette lighters and slot 2 powers the camera. Or the other way around... Either way I added another 15 fuse and it works great.
Old 06-08-2015, 01:24 PM
  #92
dv1977's Avatar
Mercedes C-Class W204 Restyle
Hi everybody! Need help it terms of this topic!
Hi!
Still can't find a solution, here is a story (it's all about w204 c-classs 2011 factory equipped with Conamd NTG 4.5 Online, but i'm sure the solution are common for SLK, e-class, c-class):
1. I've just connected my non original but still good cam to my Comand Online NTG 4.5
2. I've powered it from right rear movement light - i took the grount there also; and the anod activating wire was also connected to +12
3. After it i managed to go through the salon to my Comand and connected the video to the jack #6, the right one as showed
4. Then i entered an engineering menu and made my selection as showed
5. And also i checket this - "'External video display' (in the HU parameter menu), 'Front monitor', 'RVC'", it was NTSC so a guess it's all right isn't it? I got an NTSC cam...
6. After reseting system (off, then off the car, lock, stay for 5 minutes) i saw a new point in menu "Rear view camera" and it was already switched on "Activate on R-movement".
7. And, at the and of this all when i first made an reverse gear i saw a blank black screen with "Check for surrondings" and a back button.
What did a do wrong?? Please help ASAP, can't sleep! :-)))
Old 06-08-2015, 02:47 PM
  #93
chrisdean's Avatar
You should not wire into the reversing light. Use an "Add a fuse" and connect to fuse 71 for the cameras power.
Old 06-08-2015, 03:10 PM
  #94
dv1977's Avatar
Question What's gonna be wrong?
Thanks for you reply! But can you tell - what's wrong with a way of connecting i'm using?
Old 06-08-2015, 03:22 PM
  #95
lemonstand's Avatar
I think I replied to one of your other 3 posts. You're using the wrong FAKRA input. You said you used the 2nd green FAKRA Connextion on the right. It's the first (left) FAKRA connection. And ^^^^ he is correct about add Fuse #71. Tapping in to reverse light will just cause Unstable electricity to camera. I've read plenty post with problems where people tapped into power or a "switch" to the reverse camera light.
Old 06-08-2015, 04:02 PM
  #96
dv1977's Avatar
Thanks again! I'll try it tomorrow!
By the way:
- i took the photo with a wrong FACRA somewhere around, look - https://mbworld.org/forums/c-class-w...android-4.html
- and i still thinks it's ok to use a reverse light because in my case i'm using a special output relay (sorry, forgot to mention it) and all my wires comes through this relay - so i think that's not a problem!
Thank you for your cooperation!
P.S. Our Russian forums sucks - no one knows nothing!
Old 06-09-2015, 06:55 AM
  #97
dv1977's Avatar
Question
Hi!
Following your advice i changed a facra to the one on the left side - the result is obvious! I saw a picture! I rejoiced but much too early - the picture started to blink, then some horizontal gray bars appeared, and then black screen again.
When the time passed (3-5 minutes) the situation happened again - the picture and then blinking and then - black.
Few questions:
1.Can it be because the connection was made to the reverse light? I hoped that because of relay it can be made this way... but it's not?
Or, may be it happes because the anode and +12 are twisted together and linked to "+12" of the reverse light?
Should i detach an anode and leave only +12 AC connected?
2. I know my got an integrated parking lines (static ones). There is a small green wire and it's said in the manual that i must cut it if i don't want this lines - so guess they are enabled by default. But i can't see them in moment the camera works!
Should a make some changes in Comand NTG 4.5 Online to enable them? Or, as i heard - there are some factory lines sewn in Comand and i can activate them!
Do you know - what's the solution?
Thanks in advance for your answer!
Old 06-09-2015, 01:17 PM
  #98
chrisdean's Avatar
Do not use the reversing light, the power from fuse 71 is, for want of a better expression, a purer source and less likely to upset the head unit.
Old 06-09-2015, 02:39 PM
  #99
dv1977's Avatar
Ok for 71
I'l do 71 fuse for sure but can you show me - where is? On a photo of it is possible!
Thanks!
Old 06-09-2015, 04:20 PM
  #100
chrisdean's Avatar
Fuse 71 is in the rear fuse box by the right hand wheel arch in the trunk.
Quick Reply: Installing RearView Camera on 2012 C Class
