Installing RearView Camera on 2012 C Class
#101
Mercedes C-Class W204 Restyle
#102
Here's a picture of my add a fuse during install for reference. Hope it helps.
#103
At the risk of sounding like a smart a** it is labeled "71". I just went out and looked to verify that it's labeled. I would've taken a picture but it's covered with tape since the latch doesn't close because the add a fuse is too big and I don't want to mess with it.
Thank you, that was completely my mistake - I've just realized it has some marks on the fuse box!
Also I want to ask you again: do you know something about parking lines? How can I activate them?
And, by the way - after reading an incredible amount of information I've understood: I have to connect +12 AC to #71 fuse and also connect the activating wire to reverse light lamp - because I checked and that won't work separately from each other - only when both wires are connected the cam starts to picture!
Am I wright?
#104
Ooopps! Smartass detected! Just kidding! :-)
Am I wright?
Am I wright?
#105
But thanks anyway!
#106
has anyone successfully installed diy? and do you require the multimedia module around $400
w204 2011 c250 wagon
http://www.emeraldintegrations.com/m...ra-system.html
#108
2016 S550, 2014 C250
Been going though this DIY and there is a bunch of good info. I have a 2014 C250 with the Nav in the glovebox (Becker unit). Does that mean I don't have COMAND? Is there any way to do a camera retrofit if I don't have that? It does have bluetooth phone/audio with the control dial on the console.
#109
350 GLK, C280
DV1977, to answer your question about using the reverse light power, you need to understand that all the lights in the car are operated off the computer. There are no relays or power switches as in old vehicles. The computer pulses signals in a manner that it can tell if the lamp is blown and can actually be switching the ground side depending on which lamp. For example, you cannot go into the overhead lamp in the interior to get power for a radar detector or windshield camera. You must pull power from a DC supply such as a cigar lighter or directly from the fuse box. Trying to pull power from a light source will not only not work correctly, it can also damage the output SCR's in the computer.
The MOST optical connection loop tells the NAV screen when the car is in reverse and to turn on the reverse camera input, so rear view cameras don't need to be connected to anything but switched power, ground and video. If the camera has an extra lead to switch on for use in older vehicles, that lead should be connected to the same place as the power lead.
#110
Hello,
first of all thank you for such good guidance for installing the rear view camera.
I just have some additional question regarding the pinning of the camera.
I’m using an original MB rear view camera and it has 4 Pins.
Pin1 : Shielded cable --> Video Signal
Pin2 : White cable --> Activation line ?
Pin3 : Black cable --> Ground
Pin4 : Red cable --> Power Supply
As I understood the power supply and the activation line ( Pin4 + Pin2 ) should be connected to +12V via the Fuse 71 in the fuse box.
Is this correct ?
But in this case the camera would be always be powered on and only when entering the reverse gear the HMI will switch to the rear view camera display and show the camera picture.
Or is there some other possibility ?
Thank you for your help.
BR,
Novi
Is this correct ?
BR,
Novi
#111
Hello,
Is this correct ?
BR,
Novi
Is this correct ?
BR,
Novi
Oh and don't tap into the reverse light for power. They're too many issues with flickering screens when you do this. Good luck.
#114
2012 C200 CGI AMG Sport,2011 SLK 200 Komprs R171 2000 Toyota Land Cruiser GXR, 2007 Jeep Wrangler JK
and the cable wend from the module "installed in the rear seat wo the SAM module in the right side of the trunk, then under the rear seats on the left side under the door sills of the driver and the rear left, the under the lower panel below the steering wheel and then to the command from behind.
I Will also try to copy and upload the installation manual for it it was almost straight forward work took me about 5 hours including the front headlights as I was doing it all together the only problem I'm facing currently that everything is perfect it just didn't work.
I have to send it to the dealer to add the code "218" using VeDoc.
I checked it using the star diagnosis everything is fine except this code is needed for the cm to work and the dealer is telling me it's a 5 hours job and it will cost around $550 which is too expensive in my point of view for just adding a code to the car
#115
#116
MB C200-2012 Rear cam Instaled
Hi all,
I just instal my rear cam on MB C200-2012, head Panel NTG4.5.
Thanks all of you for very helpful guides - it WORKS.
Hi dv1977 just plug to the LEFT green conecction and it works.
#117
Hello guys, I have a 2011 C-350 coupe and seens it is the same as 2012. I bougth a rear view camera as the picture at eBay. I just install the camera and the conector to main unit into green conector (see picture) the problem is that I can’t see any image in the main screen. Can you help me if i need an interface? Adapter? Or fuse?
#118
Did you set the camera on in the engineering menu? If so I'd intercept the video feed where its still composite connection (RCA) and feed it to a TV or something just to verify the camera is producing a signal as installed.
#119
2012 C300 4Matic
The camera i bought has a small red wire coming out from RCA (yellow) connector which goes into the fakra cable. Do i have to connect this red wire to the power for the camera to work? this is at the end where it connects to fakra to COMAND. There is already red and black wire at the end where it connects to camera and i have connected those to fuse 71 and ground. I have connected everything but the video doesnt come so not sure if this red wire needs to be connected to power source. any help would be appreciated.
thanks
thanks
#121
I'm not sure what wire you are talking about, but it does need power. I have mine hooked into the panel by make brake lights on the right side. Test it with a tv or something to verify you're sending a signal.
#122
help needed, I know this is for c class, but I cant find similar post for e class.
I have e class w212 2011 tried to retrofit RR camera and on my head unit I have only one double green fakra connector 1 slot free, but everyone one else seems like having double and another one just above for reveverse camera.
My question is can I use that free fakra and connect camera to it? Will it work then I put my car into Reverse?
Sorry for my bad English, this is not my primary language.
#123
Bringing up an old thread, for powering reverse camera, in my C63 W204 Facelift (UK spec), slot #71 already has a fuse in it, but not sure for what. Is there an alternative? Not sure my fuse tap will fit with both fuses.
#124
Slot #71 is the cigarette lighter fuse. The current fuse in there has to go on top of your "add a circuit" which now goes in that slot (along with 1 more fuse for the new power to camera).
wsc (10-08-2020)
#125
