Installing RearView Camera on 2012 C Class
Old Oct 8, 2020 | 09:48 AM
  #126
lemonstand's Avatar
2014 C63 507 Edition Sedan - Mars Red
Originally Posted by wsc
Sorry one more follow up, for all W204s. that is the the way I need to put the piggy back fuse tap right? Because you can put it the other way round as well, but I'm not sure which way is the correct way for the fuse to be active. Any ideas? thanks
Are you talking about the positioning of the add a fuse?
the position really doesn’t matter as long as its making contact and you have the two fuses connected at the top of the add a fuse. The fuse # is 71. If I recall correctly when I installed mine there was a “latch” that would close over the fuses - I could no longer pull that latch down to securely hold down the fuses but I never had issues with them coming out.
Old Jul 30, 2022 | 02:18 PM
  #127
twanmadden's Avatar
w204
w204 fakra
Originally Posted by Kaewen
Update... i've found the reverse camera input. Notice the twin GREEN plug with only one cable? The reverse camera input goes in the other empty slot.
I've removed my old terminal from the black fakra cable and just plugged that into the existing free slot in the green twin connector.
Hope that is clear enough. If you guys need more help, feel free to PM me.
Hello, I know this treacd is pretty old but if possible could you tell me how to hook upthe green fakra cable to the 2 green fakra slots at other bottom, I'm having trouble with my backup camera. Thanks in advance
Old Jan 3, 2024 | 08:56 PM
  #128
kevviek's Avatar
C200
Originally Posted by chrisdean
Do not use the reversing light, the power from fuse 71 is, for want of a better expression, a purer source and less likely to upset the head unit.
Why don't people use
position 83 - Reversing Camera or
position 84 - Backup Camera Control Unit and Power Supply
