Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Lighting Guides
- Mercedes-Benz C-Class: How to Black Out Headlight Housings
Step by step instructions for do-it-yourself repairs
Finally, some proper shots of out W204
#103
There is a DIY in the DIY section for bumper removal...
Just take out the bolts holding the headlight assembly in, disconnect the electrical connectors, remove the screws holding the clear lens onplace in the oven for 10 minutes at 250 degrees then pry the lens out and away. Once thats done take the torx screws out attaching all all the chrome together and sand the chrome lightly. I used scotch brite. 2 Coats of primer and 3 coats of what ever black you want. Once its all dry carefully place it back together and put it back in the oven for 250 degrees for 10 minutes. Once thats done pull it out and gently press the lens back into the housing to reseal them, and replace the screws.
#104
Thanks![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I wouldnt even have done this on my mazda....and it was just a mazda lol.
#105
I noticed in a couple of the shots it looks like your taillights have brake lights on top and bottom...is this the case? I found your thread about the lights you bought, just wondering how they operate? Led brake/running light on the bottom, red turns, and halogen brake above?
And gorgeous car btw, reminds me of a stealth bomber lol
#106
#108
Ah, I see. Can you maybe, next time you're out at night, take a quick video and upload it so I can see? I've been looking at putting led tails in but am scared to pull the trigger. Thanks
#113
Just changed the springs (H&R super sports) with 5mm shim pads, ride quality is surprisingly good, even with my 25 and 30 series tires
#114
#118
Cool, so the bottom leds are on all the time with the parking lights, and jsut get brighter when you hit the brake? How have they held up for you?
#124
2011 MBenz C300 Sport 4matic
Blacks out grill
Hey what is a good way to black out the top 3 silver/gray flat parts of the front grill. I want to leave the 3 little chrome strips then black out the flat top part connected to those chrome parts. A guy at a shop said he could try putting vinyl on them, but I wanted your opinion on the best way. Thanks
