Reversing Camera no guide lines?
Old Sep 29, 2011 | 12:07 AM
chad88's Avatar
2012 C250 CDI
Hi everybody!
I'm new to the forum and Mercedes. I just picked up my C250 CDI yesterday, what a pleasure.
I have one quick question regarding the reversing camera, there are no guide lines visible in the picture. When I asked the sales guy he had no idea.
Is there a setting to activate them?
Old Sep 29, 2011 | 09:51 AM
until the end's Avatar
2009 c350 arctic White pano. MM HK
MB cams dont have guid lines in all models
Old Sep 29, 2011 | 12:30 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
On my 08 there was an option in the Engineering menu for them. I don't have that car any longer and the 11 doesn't have MM so I can't look it up. They were pretty useless anyway as they were static.
Old Sep 29, 2011 | 01:55 PM
joshg1001's Avatar
2017 E300
the funny thing is that my 09 does not have this option in the secret menu
Old Sep 29, 2011 | 04:13 PM
Ron Jr's Avatar
08 and 09 should have the same version of Command if you kept yours up to date. Mine was updated twice in the time I had it and I had the version checked the sevice before I traded it in. The name of the option is very misleading and it was buried in a sub menu. And it was more of a distraction then useful.
Old Sep 29, 2011 | 04:23 PM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera.
My 2011 has green lines with one yellow line. I am not sure what it represents. Maybe it represents the car that anything outside of that is OK when backing out. Who knows. I have to set up some carton boxes to see/calibrate.
Old Sep 29, 2011 | 05:33 PM
chad88's Avatar
2012 C250 CDI
Did it come from the factory with those lines?
Old Sep 29, 2011 | 06:12 PM
C300CA's Avatar
I'd think so. I enabled the camera in the engineering mode and lines showed up whenever shifting into R.
Old Sep 29, 2011 | 07:16 PM
chad88's Avatar
2012 C250 CDI
Ok ill poke around and have a look. Maybe the lines might be hardware seeing as some MB have them and some don't?
Old Sep 29, 2011 | 07:22 PM
joshg1001's Avatar
2017 E300
Well there was another thread about the guide lines that I reviewed recently. in the engineering menu 7 sub menu 7, i only have 3 pages of options, not the 4 that others have that has the SRVC Lines option
Old Sep 29, 2011 | 08:00 PM
Garry1104's Avatar
C300 4MATIC
https://mbworld.org/forums/c-class-w...vid-cable.html
It's #8 and #9 of that thread. I am going to try it out myself too since I also did the rear view cam mod on my 08 C300.
Old Sep 29, 2011 | 08:46 PM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
hey Ron, why did you get Rid of Darth after putting all that good work in? I would think you would wait one more year till 2012 to get the latest facelift? Just trying to see why someone as calculated as you would make the move you did...
Old Sep 29, 2011 | 09:23 PM
2nice4me's Avatar
2011 E350 4 Matic
My 2011 (CDN) doesn't have it either
Old Sep 30, 2011 | 12:53 PM
Ron Jr's Avatar
I was made an offer to good to refuse. Besides I didn't want to wait 6 months for aftermarket parts to start showing up for the 2012's I also like the looks of the 2011 more (except the interior).
Old Sep 30, 2011 | 12:55 PM
Ron Jr's Avatar
Try to get Command updated at your next service and it should be there. Tell the SA that the Blue Tooth cuts out at random times, this is a known issue and the Command update will fix it. But a bit of a warning if you have any music on the HD it will be wiped during the update.
