Burned Socket
Old Sep 29, 2011 | 04:49 PM
w204nyc's Avatar
2017 C63S coupe '09 C63, '15 Durango RT, '14 Jeep SRT8
Burned Socket
A friend of mine is using a bunch of ANZ_optics LED Eyelids and they keep burning out. I looked at his car and found that the socket had also burned. For the people that have had their sockets burned, what did you do? Did you just replace it and is it covered by warranty? Does anyone know the price of it?
w204nyc's Avatar
he also said they burn out every month and it's always a different one. He only drives on the weekends so I know they're not staying on too long. Any ideas?
Old Sep 29, 2011 | 06:42 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Who's your friend? I haven't had any customer recently mention to me that he's getting burned out LEDs every month. Have him contact me and email me pics of the LEDs so I can see if they were improperly installed and I can warranty the LEDs. They should not be burning out every month if properly installed.
I'll do some research on the socket and see what I can dig up.
Old Sep 29, 2011 | 08:27 PM
FAneek's Avatar
08 MB C350
I have the AZN Optics LED Eyelids for a while now and i drive my car every single day and no problem here whatsoever...he probably installed it wrong.
Old Sep 29, 2011 | 10:41 PM
Blazeitup123's Avatar
W205 c400 sport
+1
Old Sep 30, 2011 | 01:44 AM
w204nyc's Avatar
how can it be installed it wrong? He said he didn't push it all the way in.
Old Sep 30, 2011 | 01:57 AM
xolinlevh's Avatar
2011 E550 4Matic
Dirty contacts? I've had my Azn LEDs for a month now and i drive daily, never had a single problem.
Old Sep 30, 2011 | 03:50 AM
w204nyc's Avatar
When I had my c300, I had mine for about 6 months before I had one burn out. Idk maybe its his car.
Old Sep 30, 2011 | 11:11 AM
AZN Optics's Avatar
It could be any number of reasons, I can usually tell by the condition and burn off marks on the LED so if he would have contacted me, typically I'd ask for pics of both sides of the LED to see if I can identify the issue (improper install, voltage surge, corrosion from improper sealing, etc). Not saying it's his fault or not, but I didn't get anyone with that case contact me so don't know.
Old Sep 30, 2011 | 02:51 PM
w204nyc's Avatar
Yea I understand. He said he doesn't have the LED's but he says when he pulled it out, the white strip on the sides was burned off like a brown color and one was almost coming off. Im headed to meet him and I'll send the pics of the socket. He said he isn't saying it's your LED's but he's unsure why this keeps happening.
Old Sep 30, 2011 | 03:31 PM
AZN Optics's Avatar
Typical indication of over insertion is the resistors close to the voltage plate is flat against the unit, but the secondary resistor starts seperating. That's cause the clip is physically holding the first resistor down due to over insertion and the overheating is compromising the solder on the second resistor. Browning and burn off marks are normal though.
Old Sep 30, 2011 | 03:43 PM
w204nyc's Avatar
here are some of the pics
Old Sep 30, 2011 | 04:20 PM
AZN Optics's Avatar
Got pics of the other side? The other side is usually a good indicator of what happened. Yeah, that socket got scorched, but it's just some on the plastic casing. Socket should still be good though. Got a PM from your friend though and we'll start the diagnosis process and get down to the root cause.
Old Sep 30, 2011 | 04:33 PM
w204nyc's Avatar
ok hope this helps
Old Sep 30, 2011 | 05:18 PM
AZN Optics's Avatar
ok, These look like over insertion. See how the first set of resistors (which should be the first to go) are held tight still? That means the voltage clip was most likely sitting on top of it physically holding it down and causing a closed circuit, super heating the unit.
This is actually repeatable install issue....over plug the LED in on purpose, turn them on for a couple seconds, then off. Feel the LED. They'll be scorching hot to the touch. Not normal. Let it cool off, pull em out to where they should be plugged in. Turn them on for a couple seconds again, then off. Feel them again. They should be significantly cooler to the touch. Still hot, but not scorching hot. That's what they should be. Also, care needs to be taken when plugging them back into the socket as when you try to ferret out the hole, sometimes that bumps the LED back too far into the socket again, so grip the socket and LED 50/50 while plugging them back in.
Old Sep 30, 2011 | 08:17 PM
Boris0126's Avatar
2009 C-300 Sport
I have had AZN Led's for over half a year or longer and no problem what so ever
Old Sep 30, 2011 | 08:24 PM
tehc300's Avatar
C300
I'm still on my original set I purchased when Mike first did the group buy I think back in 09? never had a problem with them at all.
Mike always takes care of his customers, your friends in good hands
Old Sep 30, 2011 | 10:32 PM
w204nyc's Avatar
Yea I know, he has been great. He always took care of me and now he took care of my friend.
Old Oct 3, 2011 | 12:43 AM
w204nyc's Avatar
so has anyone replaced a socket?
