Brake problem - 2012 C300
I think I am having a brake problem. Whenever I depress the brake pedal, the braking feels likes a two-gear process mechanically. After one inch down, it shifts to another gear. I couldn't hear obvious noise, but can feel the mechanical shift clearly. If I release the brake pedal and then depress it immediately again, the second depress shows one smooth braking.
This is very annoying. When I tested drive a C300, I didn't feel this problem at all. The problem of my car appeared right at the first stop sign when I drove out of dealer's lot. At that time, I thought it could be just due to some fancy features that I was not familiar with.
Anyone has any idea what the issue could be and how serious the problem is? I think I need to take the car back to dealership for a checkout but it has to wait until next weekend as the dealer is about one-hour drive away.
Thanks for the help.
I would drive it to the dealer asap very carefully ,continually monotoring the brakes effectiveness.
Keep us informed.Good luck.
I took the car to the dealership. As expected, a technician there tried to convince me that everything is dandy. He plain simply denied that there is any "mechanical shift" at all. I asked two of my friends to try the car and they both felt the "shift" very clearly, although they don't voice strong concerns. I guess I have to wait and see whether the problem will simply go away.
Anyone knows whether it is possible to use a different dealership for car service? If possible, how to do so?
Thanks.
Just call the other dealership and make an appointment.
Since your 12 GLK is still under warranty, any reason that you didn't get it fixed?
With a newly assembled car it is usually corrected by merely pressure bleeding the system. If this does not work then it can be remedied with the actions in my previous posts.
Good luck & enjoy!
https://mbworld.org/forums/c-class-w...Caliper+return
The short & sweet versions.
Braking that Boosts Confidence and Convenience
"Lift off the accelerator quickly and Predictive Brake Priming sets the pads closer to the discs, for more immediate response when you hit the brakes. In the rain, Automatic Brake Drying gently applies the brakes periodically, to sweep away water build-up. During uphill starts, Hill-Start Assist helps prevent unwanted rollback. And a HOLD feature can make stop-and-go traffic a little easier."
armymom I was wondering are you still having problems with your brakes and if so have you taken the car to dealership and what did they tell you
