What's the current favorite all-season tire?
Here is what Tire Rack says, and yes, I know they sell tires for a living!
However, as a tire wears it's important to realize that the tire's ability to perform in rain and snow will be reduced. With 2/32" of remaining tread depth, resistance to hydroplaning in the rain at highway speeds has been significantly reduced, and traction in snow has been virtually eliminated.
If rain and wet roads are a concern, you should consider replacing your tires when they reach approximately 4/32" of remaining tread depth. Since water can't be compressed, you need enough tread depth to allow rain to escape through the tire's grooves. If the water can't escape fast enough, your vehicle's tires will be forced to hydroplane (float) on top of the water, losing traction.
If snow-covered roads are a concern, you should consider replacing your tires when they reach approximately 6/32" of remaining tread depth to maintain good mobility. You need more tread depth in snow because your tires need to compress the snow in their grooves and release it as they roll. If there isn't sufficient tread depth, the "bites" of snow your tires can take on each revolution will be reduced to "nibbles," and your vehicle's traction and mobility will be sacrificed. Because tread depth is such an important element for snow traction, winter tires usually start with noticeably deeper tread depths than typical All-Season or summer tires. Some winter tires even have a second series of "wear bars" molded in their tread pattern indicating approximately 6/32" remaining tread depth to warn you when your tires no longer meet the desired tread depth.
ContiProContact-MB Spec- 245-40-17
The 4matic has a base torque split rear bias at center diff of 45/55.
The 'NEW' 2008-mercedes-benz-c-class
4MATIC Cars Get Rear-Biased Torque Distribution:
"Under normal conditions, Mercedes sport utility vehicles distribute torque nearly equally between the front and rear wheels. However, the 4MATIC-equipped C-Class and S-Class sedans come with a planetary gear set within the center differential that begins with 45-55 percent front-to-rear torque distribution."
I think the best path forward is 2 new rear conti's, but 225-45-17, like front. (fits the 8.5" wide oem rim)
Then search ebay, dealers, etc, for a used set of your type front wheels. When purchased, put them on rear for the non-staggered lux model set-up, allowing proper rotation, and better ride and winter/rain performance in general.
Next tire set consider DWS, all 225-45-17.
Pete7874, remember this suggestion to avoid confusion:
*** All Members New and some Old, please click on User CP at the top left of page, just below the thread title. ***
Then add the following to either Profile and/or Signature , selecting buttons on the left side of that page: year, model, Sport or Lux, 4MATIC or RWD, and Location, city & state (and non-US/Canada country if needed). This helps response to issues, like tires, sales, etc.
https://mbworld.org/forums/c-class-w...g-17-reps.html
.27" using your rears up front.
.83" just moving sport rears up front.
When checking for front inside clearance at the tire, you need to consider the decreased "dynamic" clearance of the outside tire when hard cornering, as the sidewall experiences lateral shear displacement.
