Renntech C250!
So I'm from michgan. My cousins leased a 2011 E350 4M. They talked mercedes into doing renntech on their car. They explained to Mercedes Benz that it will boost the cars value in 3 years if the dealer went to sell it when there lease was done. Specifically it would boost the value 5k-7k. So Mercedes Benz ended up paying for renntech for them.
I was amazed when they told me this. I'm planning on leaseing either a black or white C300 4M coupe in June (it's a little ways away, but...). I want to get it renntech tuned. Probably ECU, exhaust and chipped(possibly).
Good luck with your new C. As always, keep up posted!
What about the set up looks so bad?
So I still am with above, why get a 250 VS a 350 if the price wasn't a matter? If you where going to then put more money into it anyways? If you like the body kit couldn't you simply have bought the 350 and put the kit on?
I am all for your choice, think its awesome, can't wait to see what they do.
I may have to stop by and take a look if I'm down that way. My dealer is a Renntech dealer
For performance comparison from MBUSA.com:
C350 ___ 302 hp & 273 ft-lbs with 0-60 in 5.9 secs
C250-T _ 201 hp & 229 ft-lbs with 0-60 in 7.1 secs.
With mods, I can see matching torque. But 100 more hp is a harder climb, that would require a larger turbo. However, most don't always run wide open to redline, so torque spec governs what you most commonly feel.
Is it a C250 sport ? I assumed so:
Getting MSRP from MBusa.com, that price difference is $5775, and does not include an extra $2500 prem-1 pkg to get heated seats on the C250.
"The block is the same as the M271" Anyone know how much hp & tq an oem blown M271 can produce?? ( for bottom end power capacity estimate)
Since the M271EVO is not supercharged, I'm hoping a downpipe and a tune should be sufficient to give the M271EVO some additional potency.
Either way, the price has to be low. Renntech did their pulley for about $700 for the M271, so I assume whatever they do now should be below $2k for it to be feasible.
Where is the intercooler on the C230K, under the SC (blower)? Is it the Air/Water type?
With a turbo, you can get more efficency (thermal) air boosting vs an eaton type SC (the Whipple SC was designed to improve that efficency, but it's got a screaming bearing sound that is nasty). And you may be able to increase the efficency of the intercooler, vs the oem C230K's.
Both systems have parasitic losses, pulley torque for the SC, and backpressure to impede exhaust flow in the turbo. But the back pressure can be reduced by upgrading $$$ the turbo. Least expensive is "boring out" the OEM housing for larger wheels, and modifying the internal WG for less restriction to flow.
MB and GM have gone with the Eaton type for a silent power boost across all rpm's ... effectively creating a larger motor. And if they use a vacuum bypass, through the IC, they should still get the great gas milage of the smaller base engine size.
I wish this site hosted spreadsheets, as I developed one for turbos. I guess there is a calculator online somewhere.
